Old 09-14-2010, 10:08 AM   #1
Default best way to clean front engine bearing
I have been wiping it down with a dry rag. Is this the most i can do?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 09-14-2010, 10:12 AM   #2
I think so. If it's gritty I just replace.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 09-14-2010, 10:17 AM   #3
no not gritty. But some of these tracks with alot of sand make up seem to be really bad for front engine bearings. I wipe it clean but you can see dirt just waiting to get in on the edge of the seals. I always take the flywheel off as much as i can to wipe the front bearing.
Mugen
Old 09-14-2010, 11:03 AM   #4
Maximo's Avatar
I usually pull the engine down...remove the front shield on the bearing and use engine cleaner and blast the bearing out from the inside outwards...of course this only works on a single sealed bearing...
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 09-14-2010, 06:20 PM   #5
deadmancourt's Avatar
Trader Rating: 11 (92%+)
how do you remove the seals on the bearings?..i am scared im gonna ruin the whole bearing lol
Rob Schneider
Special Thanks To:
S&W Fuel~Agama Usa/HobbyProUsa.com
RcRenew.com and TritonRc.com~Lucky7~Eazyrc.com
Venom-Group~Upgrade-Rc and TrackstarRc.com
deadmancourt is offline   Reply With Quote
Old 09-14-2010, 07:22 PM   #6
I was under the impression that the front seal does not like to be removed. Although no one has ever said otherwise. Doesn't matter, i have double sealed bearings on all my engines.
Mugen
Old 09-14-2010, 08:31 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
You can only get to the front bearing if you remove the flywheel and I only do that when it's time to replace the bearing.
Old 09-14-2010, 08:35 PM   #8
Jaz240's Avatar
Trader Rating: 52 (100%+)
+1 or if my engine is shot i clean my motors with Simple green and an air compressor, and then I use Kalgard 30/30 and an air compressor. every so often I will take off the backplate and pull the crank and squeeze some Acer racing Sim lube in the bearings
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-14-2010, 08:40 PM   #9
i understand what you guys are saying. But after my last race i had a broken fuel line and all the dirt and sand was stuck wet behind the flywheel and just turning the flywheel you could hear the dirt and sand. It was very gritty.
Mugen
Old 09-14-2010, 08:44 PM   #10
Jaz240's Avatar
Blow it off from the side with WD-40. not from the front or you will blast the dirt into the bearing
Old 09-14-2010, 08:58 PM   #11
losi_racer's Avatar
Trader Rating: 25 (100%+)
just wipe it imo
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-15-2010, 05:12 AM   #12
just thought i would like to share. i would like to add that one of my engines has avid bearings in it front and rear. They have been flawless so far and is smooth as butter. My LHS ordered them for 30$ shipped. I probably could have got them cheaper if i would have done it my self. So if any of you are wondering about running avid bearings in your engine, don't hesitate. They work great.
Tko's also. In my other motors. They are my top choice and are awsome!
Mugen
Old 09-15-2010, 05:43 AM   #13
Maximo's Avatar
they are just dust shields on the bearings, they come out super easy...i just use the tip if a x-acto knife and carefully lift the shield...it doesn't harm it at all.....
Old 09-15-2010, 08:04 AM   #14
Frank L's Avatar
The tko bearings are not lasting very long in my engines. They work very well in the diffs, clutch and wheel bearings but in the engines I only get 2-3 gallons or so out of them before they start making the death rattle noise. Just what I have experienced.
Old 09-15-2010, 08:15 AM   #15
Jaz240's Avatar
I have been using the ceramic engine bearings from Answer Rc. They are wonderful. They last just as long as all the others. Fronts have double seal and they are very inexpensive, and NO I am not just pushing a sponsors product. I wouldn't recommend anything I have not had great outcomes with
Best way to warm engine for bearing removal? htcurt Nitro Off-Road 23 01-03-2015 01:09 PM
First Time engine tear down questions. H9_nutter Nitro Off-Road 13 11-25-2009 11:34 AM
Disassemble Engine. tkhoo Malaysian R/C Racers 12 07-01-2004 09:15 PM
