Old 09-14-2010, 03:06 AM   #1
808gx7r's Avatar
Default diff help
i just did my diff oils...in my 808
did 5 5 1
i sat it on my j concepts stand and turned on of my front wheels as we all do.
and i noticed that the other wheel turned the same way... usally it turns oposite way
is that bad or what? how can i fix it if its wrong...
Mugen Mbx6t / O.S SPEED / Byrons / Savox servos / Futaba
Agama A8 Evo / O.S SPEED / savox / futaba
Hpi Blitz/sc10 CASTLE CREATIONS.
Driving the best quality cars in the market.
808gx7r is offline   Reply With Quote
Old 09-14-2010, 03:49 AM   #2
mp9er's Avatar
Post
try spinning it with no brakes applied and see if it spines with out going the other way and then apply brakes it should spin the other way if not then maybe theres a prob
TEAM BOB AND JIMBO RACING,
mp9er is offline   Reply With Quote
Old 09-14-2010, 04:04 AM   #3
808gx7r's Avatar
with brakes applied it spins the oposite way like it should. but when brakes arnt apply'd it spins the same way as im turning... if i do it to anyone elses buggy it will spin the oposite way like normal
Old 09-14-2010, 04:26 AM   #4
You might have over filled the diffs a bit, or its just the new oil!
I would say run the car for a tank then check again! I would say that it will be fine after a tank!
Ryper Hobbies
AKA Australia
Purple Rush Fuels
www.platypusx.com (skin industries clothing Australia)
ryWA is offline   Reply With Quote
Old 09-14-2010, 04:41 AM   #5
808gx7r's Avatar
i thought the same thing... but it wasnt that! mybe overfilled though... mybe...
Old 09-14-2010, 04:52 AM   #6
When you pull the diff out i would strip it down fully, and check the out drives turn freely in the sockets check your orings, just go through and clean everything give it a good check then stick it back together and see if that helps!
On my old xray XB8 i had the front diff feel all messed up and it turned out that it was from a lack of lube on the outdrive where it goes into the diff, it could be many things that is why i say to strip it down, clean, re oil and re lube then put her back together!
Ryper Hobbies
AKA Australia
Purple Rush Fuels
Old 09-14-2010, 05:33 AM   #7
808gx7r's Avatar
everything is new in the diff itselfi lubed up my orings etc too. when i pull the diff and turn my outdrive the other will turn oposite easly
Old 09-14-2010, 05:50 AM   #8
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
I would say if it all spins smooth put it on the ground for a tank. You have it all together right from what it sounds and xray only allows you to put ur diff in ur case only 1 way so see what it does on the ground.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 09-14-2010, 05:55 AM   #9
808gx7r's Avatar
am thinking i overfilled the diff. however once i sort my blowen up clutch bearings an deformed clutch i will see how it goes!
i sence a big rebuild happening very shortly car hasnt had much replaced on it in the last year... im sure its due for some new a arms etc, for 2 year old drive cups... no wear on them... that has to be saying something
i guess my clutch bearings lasted awhile... they've been in there since before xmas!!!
Old 09-14-2010, 06:00 AM   #10
Yeah xray does have quality, my old xray is owned by a friend and he did a rebuild, the right a arm was so warped but not broke it wasnt even funny lol.
Old 09-21-2010, 11:54 PM   #11
808gx7r's Avatar
i tryed doing the diffs again, with same results...
anyone got any idea?
Old 09-22-2010, 12:43 AM   #12
JsK
JsK's Avatar
Hmm sounds normal to me. There should not be enough drag in the driveline
(unless you apply the brakes) to diff out 5000wt fluid. I think what your seeing in other cars is a combo of worn bearings and old fluid.
JsK is offline   Reply With Quote
Old 09-22-2010, 05:55 AM   #13
tc5 man's Avatar
check and see if your wheel hub bearings and the axles are gritty my did the same thing as you on my eight-t .
Old 09-22-2010, 06:14 AM   #14
oops
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-22-2010, 06:54 AM   #15
just went through my mbx6,complete bearing replacement,shock and diff oils. 5,5,2 and it does the same thing. but, with the slightest amount of drag on driveline it will spin the other direction. i think you are fine.
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
KMRC chassis / Mini Inferno "center" Diff help please. JEFFRO503 Micro and Mini Scales 8 04-22-2009 08:49 PM
TRC LynxII diff help shadow102 Oval, Larger Scales and More 10 01-09-2009 08:04 PM
does locking the front diff help? Rufus2000 Electric On-Road 6 07-10-2008 04:51 PM
Evader Diff, Help Please!!! (brushless) wingspan Electric Off-Road 9 04-27-2005 08:51 AM
