Old 09-12-2010, 02:10 PM   #1
Questions?? Nitro Engine moves forward on idle
I have a TMAXX 2.5 and for some reason the truck is moving forward at idle. Its probrably a simple fix but it is accelerating once I turn on the radio and receiver. The brakes is also not responding well. The car was running fine yesterday. Anyone knows what could be causing this issue. I have messed with the carb running it lean and rich but seems to accelerate still. Someone Help!
shawrk is offline   Reply With Quote
Old 09-12-2010, 02:17 PM   #2
Do-Over's Avatar
Default Clutch
Probably your clutch bearings are out or some part of the clutch binding and causing it to engage at idle.
It could also be the EPA on your throttle servo is off. When you turn on your Transmitter it could be engaging the throttle servo to slightly open the carb just check when you turn it on. Does it move a little. Also check your clutch.
AE RC8T, Futaba,A-Main by Massive Mods, Hitec,
JConcepts, Fastraxx Hobbies, Team Terribles,
Do-Over is offline   Reply With Quote
Old 09-12-2010, 02:35 PM   #3
Cappy's Avatar
Trader Rating: 14 (100%+)
Is your idle too high ?
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 09-12-2010, 02:55 PM   #4
Your idle could be too high.
I'm not 100% sure how the T-max clutch works but I believe there is a slipper clutch you could have that too tight.
Or as mentioned above clutch bearings take apart your whole clutch assembly and look it over for worn parts and replace as necessary.
Also on your radio you could have turned the throttle trim too high (Small circle nob) there should be lines or a 0 somewhere around the circle.
Best of luck,
Tony
Team Losi 8ight 2.0
Team Losi Nitrotec w/ 2013
riverviewrc is offline   Reply With Quote
Old 09-12-2010, 02:58 PM   #5
jwm2's Avatar
#1 you shouldn't start your rig until the radio is on and you have tested the throttle and steering to make sure its ok.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-12-2010, 02:59 PM   #6
helivaguy's Avatar
Trader Rating: 42 (100%+)
clutch springs.
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 09-12-2010, 03:07 PM   #7
If it's accelerating after you trun the radio on, then your throttle linkage is probably messed up. You need to set it to where you carb is as far shut as your idle gap allows, when no throttle is applied.
And like the other guy said, don't start your engine until you have your radio on, and have made sure everything is responding like it should.
With you engine off,turn on your radio, and take off the air filter and make sure that when you let off the throttle you carb is closing like it should, and when you hit the brakes the carb is not moving any farther closed then it does with no throttle at all. If when you hit the brakes, and then let off the brakes your carb is opening then your throttle linkage is messed up. You carb shouldn't move at all unless you are applying throttle.
bevofrancis is offline   Reply With Quote
Old 09-12-2010, 04:12 PM   #8
Thanks for all the advice. I will check the clutch for sure. Something could have come loose..
Old 09-12-2010, 04:19 PM   #9
I'd start by adjusting the idle screw and seeing what happens. Also remember, day to day the engine tune will vary slightly meaning it could need to be leaner or richer depending on the day's conditions.
Dredd is offline   Reply With Quote
Old 09-16-2010, 01:05 PM   #10
Thanks everyone for your help.. Truck is running pretty good.. Took it to NorCal and ran it on the track for almost two hours .. Had a blast.. Tuning issues or User error.. whatever it maybe but I found the right mix on the carb.. Day to day adjustments seems to be the best advise.. I guess in this case patience is key..
SH P6-28 Pro Spec with severely aggravating problem PiGdOg Nitro Off-Road 12 03-09-2009 11:46 PM
