Old 09-08-2010, 12:22 PM   #1
Default Crankshaft "play"
When swapping clutch parts on my engine the other day I noticed there is about 1mm of in-and-out play on my JPX. Is this normal? I don't remember it doing this the last time but to be honest I'm not sure I would anyways. It is not side to side play, as I know that would mean the bearing is gone, in this case the crank actually moves in and out of the front bearing approx. 1mm. What does this mean? Motor still has great compression and runs like a champ otherwise so maybe I'm just being paranoid.
C.Harper is offline   Reply With Quote
Old 09-08-2010, 12:30 PM   #2
JFuel11's Avatar
Trader Rating: 152 (100%+)
Hello,
Was this with the flywheel removed? It is very common for most engines to have about 1mm or so play when the flywheel has been removed.
When you tighten down the flywheel nut it pulls the crank tight up against the bearings as well.
Hope this helps...
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 09-08-2010, 12:33 PM   #3
smracer31's Avatar
Send a message via AIM to smracer31
Hope this helps...
sometimes it doesn't pull it forward, you should make it a habit of pulling the crank forward, then sliding the collar on, and make sure theres no play, then tighten the nut.
smracer31 is offline   Reply With Quote
Old 09-08-2010, 12:45 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
X2
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 09-08-2010, 01:31 PM   #5
Ok excellent because that is exactly what I did, pull the crank forward and then tighten everything down. I just honestly did not remember that play before and had no idea what it meant. Glad to hear it is not uncommon! Thanks fellas!
