Old 09-08-2010, 04:22 AM   #1
Default Engine question
I put new bearings in a vspec, and when I pull on the flywheel the crank has a small amount of play back and forth or in and out, just a very small bit (less then .5 mm). I have tried a new set of bearings, different case, different p/s/r, different collet, flywheel, and flywheel spacing. So does anyone have a clue what the issue may be? Will it go away once the bearings get seated a little better? I am at a loss.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 09-08-2010, 04:31 AM   #2
Trader Rating: 8 (90%+)
Just check that the play dissapears when you install the flywheel.
manuelargentina is offline   Reply With Quote
Old 09-08-2010, 04:33 AM   #3
It's with the flywheel on
Mugen
Old 09-08-2010, 04:45 AM   #4
Thats not good man, take a look at the crankcase, maybe have some damage caused by older bearings.
Old 09-08-2010, 04:47 AM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
It is normal.
Because there is some flex in the crankshaft the bearing have to deal with it. As long there is no sideway play the bearing is fine.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 09-08-2010, 05:02 AM   #6
Thanks. My initial reaction is that it was bad. But the bearings are some of the smoothest I have ever had
Mugen
Old 09-08-2010, 08:37 AM   #7
pull the crank forward push the collet back that will stop the play
the daddy is offline   Reply With Quote
Old 09-08-2010, 01:22 PM   #8
Ambros303's Avatar
+1
Usually tightning the flywheel with the nut will pull the crank snug against the bearings but sometimes you have to help it a bit by doing the above.
Kyosho ST-RR Evo-ed // Sirio // Hitec // Sanwa
Kyosho MP9 TKI2 WC // Sirio // Savox // Sanwa
Ambros303 is offline   Reply With Quote
1/8 nitro buggy engine question Joshi Nitro Off-Road 30 12-24-2009 12:15 AM
Modded Engine Question bigterp77 Nitro Off-Road 15 06-29-2008 11:51 AM
Not your normal engine question ? SteveJa Nitro Off-Road 38 06-16-2008 10:43 PM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 03:27 PM
