8ight B/T 2.0 Upgrades Worth Having
Ok what upgrades are must haves for the 8ight 2.0 Buggy and Truggy? Which parts are worth their asking price and which parts should we avoid and why? This would be to build an all around race buggy or truggy, no bashing, strickly for racing. Thanks in advance!
hello,
raced my 8ight 2.0 alot and have more than 10 gallons on it. never had an issue or DNF during a race so i guess what am doing is good.
parts needed:
1- Alu servo horn
2- 8ight T 1.0 servo saver assembly
3- Alu servo saver arm
4- not sure of the name but you need the aluminum pieces that goes over the rear diff's outdrive.
5- i also got the answer rc shock spring retainers (the piece that holds the spring from the bottom) answer rc's has a longer lip so the spring won't pop out.
6- i use Hot bodies wheel nuts as they bite into the rim (i lost a wheel during an Amain because of the stock nut)
7- i use the 5mm titanium turnbuckles from lunsford for all 4 camber links. people say those are not needed for buggy but i better be safe than sorry. i saw many stockers strip.
those are my recommendations based on my own experience so please guys dont tell me i should and shouldn't have this or that. am helping out and dont need lessons how to run my buggy unless you are Drake, Truhe, Billy or Casey not to forget Integra, Losi racer, Zixxer
cheers
Ali
parts needed:
1- Alu servo horn
cheers
Ali
steel flywheel for buggy and quick change engine mount
The new losi covered wheelnuts have the teeth in them as well
chasis
Fioroni chasis vs. BCE witch on is BETTER and why??????
Fioroni Losi 8ight 2.0 4mm Hard Coated Chassis
BCE Losi 2.0 RACE chasis
hello,
parts needed:
1- Alu servo horn
cheers
Ali
parts needed:
1- Alu servo horn
cheers
Ali
Front and Rear Adjustable Hinge Pin Holders.
V2 Shock Tower (truggy)
Alum Rear Hubs
Alum Front Spindles
Fuel Tank Lid Pull
plus what KWT said.
Alum Rear Hubs
Alum Front Spindles
Fuel Tank Lid Pull
plus what KWT said.
Whats up with the steel flywheel for buggy?
My opinion is that there are very few MUST have upgrades. The buggy is damned good right out of the box. The only two that I consider absolutely necessary are:
I also use the following optional parts but I wouldn't call them necessary. Most are to make the car handle to my taste and to ease maintenance.
As for the steel flywheel, I feel it depends on the engine I'm running. For my O.S. Speed, which is a top-end screamer, I prefer an aluminium flywheel with two blue aluminium shoes (green springs) and two composite shoes (black springs). For my new Orion CRF Alpha MTE, which supposedly has gobs of low-end torque, I plan on trying the steel flywheel with the same shoe/spring combo.
- Aluminium servo horn (be sure to get the one for your brand)
- Locking wheel nuts (I prefer the ones made by Losi)
- Inclined 12 degree front spindle set
- Quick change engine mount system
- Aluminium rear diff carrier and shim kit
- Losi high temperature fuel filter
- JConcepts high downforce wing
