Old 09-06-2010, 07:30 PM   #1
jwm2's Avatar
Default 8ight B/T 2.0 Upgrades Worth Having
Ok what upgrades are must haves for the 8ight 2.0 Buggy and Truggy? Which parts are worth their asking price and which parts should we avoid and why? This would be to build an all around race buggy or truggy, no bashing, strickly for racing. Thanks in advance!
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-06-2010, 07:57 PM   #2
KWT-NITRO's Avatar
hello,
raced my 8ight 2.0 alot and have more than 10 gallons on it. never had an issue or DNF during a race so i guess what am doing is good.
parts needed:
1- Alu servo horn
2- 8ight T 1.0 servo saver assembly
3- Alu servo saver arm
4- not sure of the name but you need the aluminum pieces that goes over the rear diff's outdrive.
5- i also got the answer rc shock spring retainers (the piece that holds the spring from the bottom) answer rc's has a longer lip so the spring won't pop out.
6- i use Hot bodies wheel nuts as they bite into the rim (i lost a wheel during an Amain because of the stock nut)
7- i use the 5mm titanium turnbuckles from lunsford for all 4 camber links. people say those are not needed for buggy but i better be safe than sorry. i saw many stockers strip.
those are my recommendations based on my own experience so please guys dont tell me i should and shouldn't have this or that. am helping out and dont need lessons how to run my buggy unless you are Drake, Truhe, Billy or Casey not to forget Integra, Losi racer, Zixxer
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 09-06-2010, 08:07 PM   #3
losi_racer's Avatar
Trader Rating: 25 (100%+)
kwt pretty much covered everything. Although you dont need to change the servo saver assembly out anymore, they changed back to the 1.0 style w/ 2.0 spring not long after the 2.0 release
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-06-2010, 08:14 PM   #4
CaseyP's Avatar
steel flywheel for buggy and quick change engine mount
The new losi covered wheelnuts have the teeth in them as well
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 09-08-2010, 10:37 AM   #5
bad ass's Avatar
Trader Rating: 7 (89%+)
Default chasis
Fioroni chasis vs. BCE witch on is BETTER and why??????
Fioroni Losi 8ight 2.0 4mm Hard Coated Chassis
BCE Losi 2.0 RACE chasis
Serpent/Novarossi/Maxy's Fuel/Pro-Circuit tires/Ko-Propo EX-1
DESOTO RACING
bad ass is offline   Reply With Quote
Old 09-08-2010, 11:13 AM   #6
jwm2's Avatar
Those are 3 different chassis. The losi flex chassis which comes on the race roller, the bce chassis and the fioroni chassis. Theres also a matrix carbon fiber chassis that some like to run.
Old 09-08-2010, 11:31 AM   #7
Originally Posted by KWT-NITRO View Post
hello,
parts needed:
1- Alu servo horn
cheers
Ali
Good list. I agree with Casey that the steel flywheel is an absolute must. The best option money spent, period.
TPJ International
071crazy is offline   Reply With Quote
Old 09-08-2010, 11:46 AM   #8
Front and Rear Adjustable Hinge Pin Holders.
V2 Shock Tower (truggy)
Alum Rear Hubs
Alum Front Spindles
Fuel Tank Lid Pull
plus what KWT said.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-08-2010, 12:30 PM   #9
jwm2's Avatar
Steel flywheel? I have aluminum ones now, whats the difference?
Old 09-08-2010, 12:39 PM   #10
CHOAS's Avatar
How do you tell what one you have? I have a new b2.0 & t 2.0.
Whats up with the steel flywheel for buggy?
CHOAS is offline   Reply With Quote
Old 09-08-2010, 01:49 PM   #11
Slider30250's Avatar
The steel flywheel because of the heavier weight will put the power to the ground smoother and easier, less wheelspin
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 09-08-2010, 03:06 PM   #12
Signal151's Avatar
My opinion is that there are very few MUST have upgrades. The buggy is damned good right out of the box. The only two that I consider absolutely necessary are:
  1. Aluminium servo horn (be sure to get the one for your brand)
  2. Locking wheel nuts (I prefer the ones made by Losi)
I also use the following optional parts but I wouldn't call them necessary. Most are to make the car handle to my taste and to ease maintenance.
  1. Inclined 12 degree front spindle set
  2. Quick change engine mount system
  3. Aluminium rear diff carrier and shim kit
  4. Losi high temperature fuel filter
  5. JConcepts high downforce wing
As for the steel flywheel, I feel it depends on the engine I'm running. For my O.S. Speed, which is a top-end screamer, I prefer an aluminium flywheel with two blue aluminium shoes (green springs) and two composite shoes (black springs). For my new Orion CRF Alpha MTE, which supposedly has gobs of low-end torque, I plan on trying the steel flywheel with the same shoe/spring combo.
Durango DNX408 - Orion Alpha CRF MTE | Nitrotane | Competition Heat | JR Racing | Savox | AKA Tires | Ascendancy
Losi 8IGHT 2.0 - nVision S21 R | Nitrotane | Competition Heat | JR Racing | AKA Tires | Outerwears | JConcepts | DE Racing
Losi 8IGHT-E - Excelorin Brushless | HITEC | 4s G-Force LiPo | AKA Tires
Signal151 is offline   Reply With Quote
