Old 09-07-2010, 10:54 AM   #16
How often do you change bearings in clutch? Standard bearings, not ceramic. I have to replace mine every 2 litres (1/2 gallon) as they don't have any grease after that period of time. I use Losi HD bearings. Can i just put new grease in them and run them for another 1-2 litres? If so, what do you use to take out a rubber bearing seal?
Donat is offline   Reply With Quote
Old 09-07-2010, 11:00 AM   #17
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I blow all the grease out of the inside bearing before running them.... leave just a tiny bit in there. The outside one doesnt matter as its not going to oil down my clutch.
clutch bearing life is entirely dependant on mesh, alignment and chassis flex. I also always install new bearings before any main for piece of mind. So I'll install new bearings before a main, and run them at the next race all through practice and quals, then replace again before the main. Thats usually over 1/2 gallon and theyre in good shape, I've used that routine for years and cant remember the last time I had a clutch bearing failure
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 09-07-2010, 11:30 AM   #18
Jaz240's Avatar
Trader Rating: 52 (100%+)
Most excellent system Tony. That's the way to go and a great example for racers to follow. Most people don't realize that without proper clutch maintenance it does not matter how fast they are
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-07-2010, 11:36 AM   #19
And what bearings do you use? Losi are very good but quite expensive. Are there any cheaper ones that are good for the clutch? I use ProTek in the whole car exept the clutch. I'm not sure if they will do the work in such extreme conditions?
Old 09-07-2010, 11:42 AM   #20
I use Avid revolutions all through my cars.....
Old 09-07-2010, 11:42 AM   #21
Jaz240's Avatar
Try the losi clutch pack from Answer Rc. You get 4 of each size and they are very reasonable
Old 09-07-2010, 06:44 PM   #22
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
I also use that method of clutch bearings after I had one bearing failure during a Amain at a RC Pro Race. I will put new clutch bearings in before any main!!
This the biggest reason I started this post to see what people are doing for bearing maintnace. I agree with all if they are gritty then throw them away but since I take the time to tear down a car and go thru everything rebuild diffs....shocks etc... whats another few min of letting good bearings or even soaking new bearings in this fully synthetic oil it has to help fight against rolling resistance because more rolling resistance you have thats more HP being robbed..but maybe im just having to munch time to think about this crap...LOL
Lance Plant
Sponsors: Team Associated~Reedy~LRP~Pro Line~Avid RC~Airtronics~Werks Racing
TXRC8racer is offline   Reply With Quote
Old 09-08-2010, 08:02 AM   #23
Integra's Avatar
Too much time.
Old 09-08-2010, 08:25 AM   #24
+1 on that routine, Im going to try it . Thanks Tony
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
TC3 maintnance TuxRacer Electric On-Road 12 04-30-2004 01:23 PM
