Old 09-05-2010, 08:54 PM   #1
koopesv's Avatar
Trader Rating: 18 (95%+)
Default Oil or Springs
I just wanted to know what would be a better adjustment, to change the oil or the springs? I dont want to know which one would be faster, just the better solution. I ask this because im getting more chassis clapping then I would like.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 09-05-2010, 09:13 PM   #2
tc5 man's Avatar
i would, say if your at the track and want to adjust the shocks the faster thing to do is to change to a stiffer spring so the chassis slapping will stop.
if your at home at your workbetch then go to heavyer oils in the shocks.
ethier way your will notice quite a diffrence from just changing the spring.
Old 09-05-2010, 09:48 PM   #3
jmaxey51's Avatar
the chassis slapping isnt always a bad thing. mine slaps if i over jump or come up short on a jump, if you land in a weird way or not level to the ground it will slap no mater what. stiffer springs is usually the best and quickest but changing shock oils can help a TON, i went up to stiffer springs just because i didnt have time to change oil and then i changed oil and had to go back to lighter springs. also running different rebounds helps alot too. i almost always run 100% rebound and sometimes i run 75% for smoother tracks, but thats all about what the driver wants, i know some run 0% rebound. also different piston sizes help, i usually drill mine so i can run thicker oil, but you really have to know what your doing when you drill them, you can mess one up in a heart beat.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 09-05-2010, 09:54 PM   #4
merdith6's Avatar
Default Try
In the front shocks go one spring stiffer, usually works great, then go up 10wt in the oil too. If you go to thicker oil you usually need a stiffer spring or it won't rebound properly, too slow,. Another way that I've found works wonders is to go to the one smaller piston hole size....Then keep the oil the same as before, and try one stiffer spring. I hope this helps, but as a rule
piston first, oil second then choose springs accordingly.......
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 09-06-2010, 07:12 AM   #5
koopesv's Avatar
How do you measure shock rebound %? How do you get the different % rates?
Urban Heat Racing
Old 09-06-2010, 10:07 AM   #6
jmaxey51's Avatar
it is how much the shock comes back out with no springs on it. the way you do it is you push the shock up to how far you want it to shoot back out and then tighten the shock cap down.
here is a good way to build shocks: http://www.tytessman.com/tips/building_shocks.html
Old 09-06-2010, 10:29 AM   #7
tc5 man's Avatar
heres, what sucks though with rebound it never stays the same after you run it on the track . espially with the rubber bladders
Old 09-06-2010, 11:04 AM   #8
8ight-racer's Avatar
If you drill a hole in the cap the rebound won't go up as the shock heats up.
Palm Desert R/C Raceway - www.palmdesertrcraceway.com
JQ Products, Pro-Line, TKO, Buku, Werks Fuel, Savox, A Main Hobbies, and Uncle Don's Hobbies
8ight-racer is offline   Reply With Quote
Old 09-06-2010, 11:07 AM   #9
tc5 man's Avatar
i know i just dont like rebuilding the shocks more than i have to with that mod. i hate doing shocks !
Old 09-06-2010, 12:21 PM   #10
jmaxey51's Avatar
thats not true at all.... you need to rebuild your shocks with all new o rings, mine holds the same rebound for atleast 3-5 races easily, but i usually re-do my shocks every other race because i can tell that they are thinning out. but now ive been drilling the pistons so i can run thicker oil so it lasts longer.
Old 09-06-2010, 02:13 PM   #11
By drilling the caps, how do you keep dirt out from geeting inside the cap? Any tricks? Or u just have to rebuild each and every race?
liquidsky is offline   Reply With Quote
Old 09-06-2010, 02:26 PM   #12
I use a small piece of leftover foam from the inside of my air filter element. This also helps to return the bladder back to its normal shape after the rebound.
Sponsored by My Kids' Inheritance
Serpent S811 Cobra | Novarossi Plus 21-4T | Airtronics M11x | Savox Servos
mthird is offline   Reply With Quote
Old 09-06-2010, 05:42 PM   #13
jmaxey51's Avatar
ill never drill the caps. no point IMO but i drill the shock pistons.
Old 09-06-2010, 05:57 PM   #14
You are suppose to drill the cap right in the middle. It is a popular mod for Losi cars.
Old 09-06-2010, 06:02 PM   #15
tc5 man's Avatar
well , it might be a popular mod for the losi cars but heck if i like to rebuild my shocks earier than i need to.
i race on a dusty track every other weekend.
Mod motors, Losi diff oil, xray springs, Losi tires, deans jig, glow plugs XMSRacing R/C Items: For Sale/Trade 7 06-02-2010 07:33 PM
Returning to R/C in 2010, Associated RC8B or Losi Eight 2.0? 190mph Nitro Off-Road 61 11-27-2009 10:52 PM
Mbx6 or Hotbodies D8 halfman Nitro Off-Road 46 04-03-2009 11:19 AM
AE 16mm BIG BORES shock oil? TXRC8racer Nitro Off-Road 17 02-24-2009 09:13 AM
