Old 09-02-2010, 03:40 PM   #1
K-Line's Avatar
Default Mach 427 Problem
Alrighty ive been doing electrics for years now and have recently gotten into nitro and have apsolutly no experience. so i was cleaning everything and took the heat sink off and that plate that the glo plug screws into i put it back together and tried to run it and it wont even pop. WHAT IS MY PROBLEM? i really need to get this thing going!!!!!!!!!!
K-Line is offline   Reply With Quote
Old 09-02-2010, 03:47 PM   #2
Trader Rating: 24 (100%+)
Put a new plug in the thing.. FYI, try to keep the engine together, there is no need to open it up to clean anything unless your replacing bearings.
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 09-02-2010, 03:53 PM   #3
K-Line's Avatar
but i checked the plug and it was still glowing
Old 09-02-2010, 04:00 PM   #4
Did you prime the fuel line?
.....), ---.(_(__)
Old 09-02-2010, 04:58 PM   #5
K-Line,
I personally own 2 427's and a "Big Red" (same motor, little bit different sleeve set up). They are great engines and provide good power with great reliability. They also hold a tune well and aren't too finicky. Almost all Dynamite motors are bargain HP motors. The only thing is if you toast one, it is pretty much a done deal cause the replacement parts will put you up close to the same price as a new motor. But, keep rockin the Mach 427.
If you removed the head button (appropriate term here) I can only imagine why. But, upon re-assembly, it will not fire, then there can be a few things that are wrong. First, check the obvious - fuel getting to carb, the glow plug and igniter you are using are actually glowing the plug, and hopefully you haven't messed with anything else, like needle settings or anything. It could be possible that you failed to install the head shims upon re-assembly - who knows.
One can ask a lot of questions, but you should tell us 1) Why you removed the head button 2) How much wear does this engine have? 3) Is this engine properly sealed from the get-go 4) What nitro % and glow plug you are running?
I ran the McCoy MC59 in mine almost all the time - was a very versatile plug.
moto775 is offline   Reply With Quote
Old 09-02-2010, 05:05 PM   #6
Suspended
Trader Rating: 202 (96%+)
just beacuse the plug is glowing with glow ignighter, doesent mean the plug is good.
inferno13 is offline   Reply With Quote
Old 09-02-2010, 05:33 PM   #7
K-Line's Avatar
Then engine has about a 1 1/2 gallon through it and is still in good shape and has good compression. I run 20% with a hot plug and it has run perfect. For now I will just get a new plug and go from there.
WHAT DO YOU THINK ABOUT THE LOSI MACH 427 pimptasticksilk Nitro Off-Road 31 03-23-2014 05:34 PM
HELP, Losi 8 rtr mach 427 tuning gremlins. Hitman Racing 1 Nitro Off-Road 19 03-19-2010 09:46 PM
Losi L8ight Roller, Mach 427, hitec 965 NitroDirtMan R/C Items: For Sale/Trade 16 01-14-2010 05:11 PM
losi Mach 427 seized! elkman Nitro Off-Road 8 04-23-2009 06:02 AM
Mach 427 in a MBX5T - Best pipe? Jason Halvorson Nitro Off-Road 27 11-16-2007 06:57 PM
