Old 08-30-2010, 04:31 PM   #1
Shadowhope's Avatar
Default rear diff problem
i have a problem with my rear diff when i turn the back wheels it feels like its slipping andnot turning the diff rod. any suggestions on how to fix this?
-----Team Losi-----
***Losi 8ight 2.0***
__Power Master Fuel__
AKA City Block Tires
Spektrum DX3S
Shadowhope is offline   Reply With Quote
Old 08-31-2010, 03:33 AM   #2
fattyalan's Avatar
im pretty sure thats normal...it should make the other wheel (opposite) the other way...
when you roll the both wheels at the same direction is should make the CVD move...
Hot Bodies D8
O.S V-spec EB mods
Spektrum DX3R
Nitro-X Fuel
fattyalan is offline   Reply With Quote
Old 08-31-2010, 05:53 AM   #3
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
If the diff is locked up, screaching and has oils theres no issue. If the oil gets really dirty its time for rebuild and if you run a car that needs a rebuild it drives very unsettling. It sounds normal but if it dont feel right pop the rear end all off and check the bearings, gears, diff and if oils are old then while you got it apart change them aswell.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-31-2010, 05:30 PM   #4
Shadowhope's Avatar
well it doesnt have any grease on the gears so that may be a problem also when i drive it it dounds like something hittine a flap like on the wheeel of fortune lol but nothing is hitting it it is something screwing up in the diff
-----Team Losi-----
Spektrum DX3S
Old 08-31-2010, 05:42 PM   #5
So, you opened up the diff and there was no oil in where the spider gears are or are you talking about the ring and pinion gear having no grease on it?
If the ring and pinion have no grease all you need is just a tad on them. The less the better.
Look at the outside of the ring gear for rounded out wear. Sometimes it's hard to see if you dont know what to look for. If it's worn down, chances are the pinion and ring gear were skipping teeth making that "flap like sound" you hear and describe. Sometimes you can get away with shimming the gears if there not that bad but if you race it dont take that chance, just replace them. Other times you hear a chattering sound that can come from the disc brakes. Some guys use springs on the shaft inbetween to push the "pads" away from the disc when you let go.
Hope that helps.
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 08-31-2010, 05:49 PM   #6
Shadowhope's Avatar
Hope that helps.
i think im either going to bu a pinion gear and the larger gear that the pinion gear turns
-----Team Losi-----
Spektrum DX3S
Old 08-31-2010, 05:53 PM   #7
Thats your ring and pinion
.....), ---.(_(__)
Old 08-31-2010, 07:11 PM   #8
Shadowhope's Avatar
ok im going to buy those 2 parts because i know that it is probly one of those 2 parts right??
-----Team Losi-----
Spektrum DX3S
Old 08-31-2010, 09:47 PM   #9
Before just buying stuff if ur budget is tight take it all aprat and check it out. No matter what eventually ur ganna have to so why not do it first to make sure before buying parts? Yeah for spares but theres another order you will need if its just a bad bearint etc. Just take it apart and look im sure the diff isnt hurt or messed up if its an rtr then it should be fine if it hasnt be taken aprt and lost shims and stuff.
Old 08-31-2010, 09:55 PM   #10
tc5 man's Avatar
man how many runs have you had on the eight-2.0 ?
im just , suprised that happen already i been running my 1.0 eights and never had that problem even after 3 gallons .
tc5 man is online now   Reply With Quote
Old 09-01-2010, 05:34 PM   #11
Shadowhope's Avatar
well i took it apart and i done see nothin wrong except one bearing was fried in the alrger gear but i dont think htat would have broke anything so i am going to order some bearings for my engine and bearings for my dif and both of those gears
-----Team Losi-----
Spektrum DX3S
TT01 Drift / Rear Diff problem. Front and Rear Wheels go in opposite directions! tapeykev Electric On-Road 17 01-02-2010 08:12 AM
xxx4 breaks rear diff StampedinIT Electric Off-Road 21 12-27-2008 07:19 AM
TRF415 REAR DIFF 16skyline Electric On-Road 9 08-28-2007 09:29 AM
Revo Rear Diff rcfreak24 Monster Trucks 8 12-27-2004 10:37 PM
Diff problem with a TC3 Smalls Electric On-Road 13 07-15-2004 08:42 AM
