Old 08-30-2010, 09:30 AM   #1
Mind_Reader7's Avatar
Default Engine runs fine, the car won't move. Is my gear box set wrong?
Ok guys, so on my little Windhobby buggy, I stripped the large gear on it, and the replacement arrived yesterday. I changed it, but I'm still learning bits and pieces. After putting it all together, I started it up, and it started fine, however the buggy didn't move. It seemed to roll forward very slowly as I hit a higher RPM, I assume this was the vibration moving it forward though. The gears appeared to be moving fine.
I'm assuming the bearing on the large gear is a one way beaing, and I've got it on the wrong way or something? Will take pics if required.
Also, on the gear assembly consists of a metal wheel, small gear, large gear. What is the metal wheel? It has 2 nuts on it, one hold it to the gear axle thing, and I'm not sure what the other one does.
Mind_Reader7 is offline   Reply With Quote
Old 08-30-2010, 09:36 AM   #2
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Does it have a slipper clutch setup at all? Maybe it's loose? Have you checked the clutch setup? I'm not familiar with the Wind Hobby Nitro stuff at all....I only have a few WH electrics that use a slipper clutch setup.
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 08-30-2010, 11:41 AM   #3
koopesv's Avatar
Trader Rating: 18 (95%+)
Have you checked the grub screws that holds the center outdrives? Thats was what was wrong went that happen to me. But I also dont no anything about wind hobby.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 08-31-2010, 10:04 PM   #4
Ok guys, my assumptions were correct, the 1 way bearing was the wrong way around. Thanks for the help.
My buggy is just a HSP warhead ripoff. It runs like a beast though. I just did a few jumps in my small back yard, got a bit of air, and upon hitting the ground, I did 3-4 rolls, car was fine.
Old 08-31-2010, 10:20 PM   #5
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
1 way bearing on the spur? weird, but atleast it wasnt a big issue lol. No buggy should break from a lil jump and tumple if so i wouldnt repair it lol i would sell it and move on. Now if your jumping wrong and break somthin thats a diffrent story lol.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 09-01-2010, 11:22 PM   #6
Damn, a grub screw on the gearbox must have come out yesterday. Will buy some more I guess, but it was a rather important screw.
Team Associated TC4 Kenshin Electric On-Road 15283 08-11-2017 03:16 PM
