Old 08-30-2010, 07:37 AM   #1
Trader Rating: 15 (100%+)
Default Glow plug question
I have a almost new RB s-5 motor with a long header and OS 2040 pipe. and I'm having glow plug issues. I am having problems keeping the glow plugs working. The plugs are not distorded or broken but after a tank or 2 they stop working. This happen to the RB plug that came with the motor and a #6 McCoys. I also used a MC59 and that last a while longer but still died. The motor is smoking on the top at Full throttle. The motor is a little rich on the bottom still but not sure if thats causing the problem or not. Please help.
Mike
mdhyams is offline   Reply With Quote
Old 08-30-2010, 07:38 AM   #2
Maybe a shim is needed?
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-30-2010, 07:40 AM   #3
According to the book that came with the motor, it only needs to be shimmed if using of 25%.
Old 08-30-2010, 07:43 AM   #4
ok, I would post in RB thread... there are some team drivers over there.
Old 08-30-2010, 07:50 AM   #5
jmaxey51's Avatar
i think i read somewhere that people are running McCoy 8 or O'donnell 99 plugs... also check the play in the rod, i was having the same issue and the crank was out of tolerance and was popping glow plugs left and right. it took my 5 glow plugs to figure it out.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 08-30-2010, 08:06 AM   #6
it is 99% one of two causes, either your running lean on top or you have too much compression, i would add a copper shim aswell as lean the bottom 1/2hr and richen the top an 1hr
blackbeardrollo is offline   Reply With Quote
Old 08-30-2010, 08:06 AM   #7
i read that also, he motor has about 3/4 of a gallon on it. They motor is still tight. I was wondering if the rich bottom is putting the cold plugs out. The MC59 worked all thru break in and for the first few heats before it died. The 2 cold plugs lasted less than a tank each.
Old 08-30-2010, 08:08 AM   #8
could be, I personally had your same problem and would go through 3-4 plugs a day. my temps were ok but it was drasticlly lean on top that would burn the plug up after a tank or so.
Old 08-30-2010, 08:13 AM   #9
Were your plugs breaking or discolored, pushed inside or anything?
Old 08-30-2010, 08:21 AM   #10
wingracer's Avatar
Trader Rating: 23 (100%+)
How much nitro? 30% you might need to add a shim.
Try colder plugs. MC8 would be worth a try. MC59 is a very hot plug that wont take much abuse.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-30-2010, 08:25 AM   #11
20% Nitro.
I tried a mc6 and it last about 2 tanks. The mc59 is the only thing that i have found that last very long. Its really got me confused.
Old 08-30-2010, 12:09 PM   #12
tc5 man's Avatar
Originally Posted by mdhyams View Post
20% Nitro.
what im using, is a odonnell #100 meduim plug in my s5 just dont run the bottom to rich or they will go in no time. and im running 20% race blead
i know also, the odonnell #77 plug is for low nitro content at 10% to 20% but it says its for 1/10 cars so i dont know.
Old 08-31-2010, 11:41 AM   #13
pitpop's Avatar
MC59 is too hot for that engine, try an MC9 or 8
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 08-31-2010, 04:50 PM   #14
What fuel are you using? I had a similar problem with my FMS. It would keep fouling plugs whenever I let it load up. I was using Sidewinder 25% pro blend which from what I was told, is all castor based oil. I tried some world's blend and no more problems. So you could be using fuel with too much castor.
Dirtdobber is offline   Reply With Quote
RB C6BB glow plug question Swampracer Nitro Off-Road 10 09-09-2008 06:23 AM
oddonnel glow plug question zixxer Nitro Off-Road 9 04-12-2008 10:23 PM
