LOSI 2.0 INCLINE SPINDLE.......................
#46
run 1mm adapters on the front of your 2.0s to stop the rims from rubbing on the webbing, you tards. and I guarantee my mugen will out handle, in mid and out of the corner any battle tank losi out there buggy or truggy.
used to drive a losi, always bmainer, went to mugen and last 6 races TQd and and always podium now! something has to be said about that!
talk all the junk you want i guess the truth hurts!
#47
#48
What is your location?
#49
#50
Mugen have mid corner push to be exact. Losi got plenty of steering from entry to exit. Way too much sometimes. More is better than less.
No way Mugen can beat a Losi in the terms of steering
#51
#52
If your that good, you should go run with the AE and LOSI boys in the Pro class.
#53
Here's a link just in-case you can't find it.
http://www.rctech.net/forum/nitro-of...ugen-mbx6.html
Bye Bye.
#54
#55
I've got an idea. If mugen's are so great why don't you go troll in the mugen forums and leave us alone!
Bye Bye.
Bye Bye.
#56
#58
OK need some help to sort this out.
What are the pros and cons of the followingn a 8T 2.0
10* reg spindle
12* reg spindle
10* incline spindle /carrier set
12* incline spindle /carrier set
Looking for what they do ie turn in mid corner exit + or - rough track ,high speed,high bite, tight track,low bite ect.
I have the v2 rear towers also so what set up do I want for a Medium length,rough,dry,low grip track .
I think I want more mid corner steering,less turn in,and settle down the rear end on exit a little.Tends to kick out on throttle on exit.I was thinking 12* inclined spindle/carrier set
What about camber link legnths as I know at one point I used front links on the rear with the v2 but don,t remember whats on there now.
10* reg spindle
12* reg spindle
#59
#60
