Old 08-29-2010, 04:37 PM   #1
Shadowhope's Avatar
Default clutch bell housing
ok so the screw that holds the clutch bell housing on is stripped sorta cause when i try unscrewing it the alan wrench just turns its basically a round hole now so any suggestios on getting it off
-----Team Losi-----
***Losi 8ight 2.0***
__Power Master Fuel__
AKA City Block Tires
Spektrum DX3S
Shadowhope is offline   Reply With Quote
Old 08-29-2010, 04:42 PM   #2
screw off bit, will do the trick.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 08-29-2010, 04:46 PM   #3
tc5 man's Avatar
i had the, same thing happen to me before what you do is if you have a dremel use, the cut off wheel and make a flat line on the front of the screw so you can use a flat head to unscrew it. and make sure you dont hit the teeth on the bell with the cut off wheel.
also i would, get a hex tool its much easier and when you tighten the clutch bell screw push in while you are turning it.
Old 08-29-2010, 05:12 PM   #4
Shadowhope's Avatar
but the screw isnt sticking out far enough for it to be able to be cut
-----Team Losi-----
Spektrum DX3S
Old 08-29-2010, 05:16 PM   #5
tc5 man's Avatar
oh i guess you could use a screw bit to back it out.
Old 08-29-2010, 05:20 PM   #6
Shadowhope's Avatar
screw bit??? what is that?
-----Team Losi-----
Spektrum DX3S
Old 08-29-2010, 05:23 PM   #7
tc5 man's Avatar
i forgot, what its exactally called but you put it in the drill and use reverse to back it out.
Old 08-29-2010, 05:25 PM   #8
they mean a screw extractor bit....
13btt is offline   Reply With Quote
Old 08-29-2010, 05:29 PM   #9
Bugman's Avatar
Just Go buy a screw extractor you can get them at any local hardware store or lowes or home depot you can buy a whole kit from sears craftsman makes a nice set around $40.00 well worth it.
Jack Appice
Bugman is offline   Reply With Quote
Old 08-29-2010, 05:33 PM   #10
Shadowhope's Avatar
but it is a v screw inside a washer so idk how it would get ahold of it
-----Team Losi-----
Spektrum DX3S
Old 08-29-2010, 05:40 PM   #11
tc5 man's Avatar
v screw ? i never heard of that but i use the clutch screw with a flat head hex screw that comes with the eight -t roller.
i dont know how you are going to get it out.
Old 08-29-2010, 05:47 PM   #12
Shadowhope's Avatar
v screw is the head of the screw goind down into a V
-----Team Losi-----
Spektrum DX3S
Old 08-29-2010, 05:49 PM   #13
tc5 man's Avatar
do you have a pic ?
Old 08-29-2010, 05:51 PM   #14
Shadowhope's Avatar
do you have a pic ?
yeah il take some from different angles
-----Team Losi-----
Spektrum DX3S
Old 08-29-2010, 05:52 PM   #15
cordarrow's Avatar
Trader Rating: 17 (100%+)
He's talking a flathead screw in a cone washer...like an AE blue washer.
I saw one today on a clutch...no clue why.
You have very little to work with....slotting is not an option...you'll leave nothing of strength to resist removal torque.
Extractor is about the only option...but much finesse will be required to avoid a complete butchering in a fastener this small.
Tell ya' what....if you were to dremel the washer away by whatever method, trying to avoid the screw...you could get a grip on it with pliers or visegrips or the like...
Once the pressure of the washer is gone, it may only take your fingers to remove it...
cordarrow is offline   Reply With Quote
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 05:38 PM
Traxxas Jato and 3.3 parts (EZstart, brakes, 20T clutch bell, etc.) btolenti R/C Items: For Sale/Trade 13 12-12-2009 07:27 PM
How do you remove the pinions off the clutch bell? Ryan41 Nitro On-Road 14 04-11-2007 01:03 AM
