Old 08-30-2010, 04:16 PM   #106
tc5 man's Avatar
Originally Posted by JAMMINKRAZY View Post
That's not how it works bud. Every servo horn is different. Every vehicle is different. Every linkage is different, Etc... You have to adjust the trim to suit. That's not a centering problem, or a servo problem, or even a problem. User error.
heres what , i do on my radio i set it to 0 on the steering trim and than press on the horn but when i put it on it wont go on at 90 @.
so i dont see what im doing wrong than .
i adjust the steering linkage so it can reach the servo horn.
tc5 man is online now   Reply With Quote
Old 08-30-2010, 04:22 PM   #107
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
What I'm trying to explain is that it isn't necessarily supposed to go on at a 90 degree angle with the trim set at 0. That's the purpose of a trim setting. It doesn't really matter if the servo horn goes on at a 90 degree angle with the trim set at 0. If it doesn't, you just TRIM it so that it does. Simple enough really. Do you understand now? Or do I need to explain it some more?
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-30-2010, 04:26 PM   #108
tc5 man's Avatar
i get it but why does losi tell you to have it at 90@ ?
i just know the futaba servos ive used centered perfect every time.
Old 08-30-2010, 04:31 PM   #109
Losi tells you that because that's where it is supposed to be TRIMMED to. As in that's how you're supposed to set it on your radio. It doesn't say anything about it being 90* at a 0 trim setting. That's why they tell you to have it trimmed to 90*. Because it isn't always gonna be 90* at a neutral trim. Again that's the reason for a trim adjustment in your radio.
Your Hitec servo centers perfectly too. A servo that doesn't center properly is a servo that doesn't return to the same place every time. If your Hitec returns to the same spot every time, regardless of the trim setting or servo horn angle, then there is NO problem with it.
-Koby Kubrin-
Old 08-30-2010, 04:35 PM   #110
Arco's Avatar
No, 2.5 and 2.6mm screws ARE different. Not by much, but they are different. I learned the hard way that it really is better to have a 2.6mm screw in Hitec servos. The 2.5's will work fine for awhile, but eventually they will start to back out on you if you don't use loctight.
I always use a dab, for good luck and all.
OverdriveRC.com
"Promote and Support"
Arco is offline   Reply With Quote
Old 08-30-2010, 04:36 PM   #111
tc5 man's Avatar
oh i , see yea i adjust the trim to make it track straight anyways and the wheels to return back there where i have to trim at .
although, the $60 diginal hitec servos do have a problem with centering badly after a while or so. they most use cheap motors in the ones that are way cheaper.
Old 08-30-2010, 05:14 PM   #112
merdith6's Avatar
Default Here is the right screw....
http://www.amainhobbies.com/product_...-Head-Screw-12
It's a 2.6mm thread.
Best price I've seen, and you get several screws. The hex head is for a 2mm wrench so you can get it tighter than those horrible phillips screws, just a dab of thread lock and your set...I recommend using a washer under it if you use plastic servo horns just because.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 08-30-2010, 05:21 PM   #113
KWT-NITRO's Avatar
some people hate to adjust the trim while setting up the car. i understand because many of my friends are like this. they want to adjust the trim only while driving, if its your case, you have the SUB TRIM option. set your normal trim to zero and adjust the sub trim till you get the 90 degrees horn.
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 08-30-2010, 06:15 PM   #114
really, how much torque you really need for steering in a buggy?
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 08-30-2010, 06:22 PM   #115
tc5 man's Avatar
well for a truggy i would say about 300 oz like im using.
for a buggy well you already know what i said about that.
Old 08-30-2010, 06:23 PM   #116
tc5 man's Avatar
well for, a truggy i would say about 300 oz but im running a 333 oz servo for the steering.
Old 08-30-2010, 07:30 PM   #117
sarcasm, bud...most world pro's run 170 to 200 oz, and they are fast...
Rui Almeida
Hamilton, Ontario
CANADA
Old 08-30-2010, 08:06 PM   #118
tc5 man's Avatar
i know well if thats what they run than they know better than us lol.
Old 08-30-2010, 08:32 PM   #119
jmaxey51's Avatar
well the reason they run them is for the speed of the servo... they can afford to replace them every race. they have the servo savers locked down and with under 200 oz they wont last long at all...
im going to start running over 350oz on buggy and truggy...
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 08-30-2010, 08:54 PM   #120
tc5 man's Avatar
im suprised that the 333 oz servo isnt working for you on your truggy
>>>NEW HPI Savage XL w/ Big Bores, JR 8711 steering servo and more.. JP116 R/C Items: For Sale/Trade 70 04-21-2009 02:40 PM
I Need a Good Steering Servo insanewulf Nitro On-Road 52 12-22-2007 05:19 PM
steering servo whats the best on a budget? rltanner Nitro Off-Road 41 09-26-2007 05:06 PM
Best 1/8th scale steering servo?? cjaeckel Nitro Off-Road 39 06-15-2007 05:20 AM
