Old 08-29-2010, 09:23 PM   #91
jmaxey51's Avatar
Originally Posted by tc5 man View Post
i adjust the, trim so i will track straight it does actually somewhat go to the left but than again i could use sub trim. na i cant leave my at 0 ethier now.
i wish i can find the gears for it i know that whould fix it .
the wheels do center back when i turn left and right .
if it does that, then you have nothing to worry about, and if it didnt, send it to hitec because thats not the gears, thats the motor... hitec does have a 1 year warranty, and its no questions asked, ive sent in quite a few 35-50 dollar ones when i was using them for throttle/brake in buggy.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 08-29-2010, 09:26 PM   #92
tc5 man's Avatar
yea i will, send it out this week by the way have you ever had the screw come out of the steering servo i did no steering lol. i use locktite on the screw now.
tc5 man is online now   Reply With Quote
Old 08-29-2010, 10:05 PM   #93
jmaxey51's Avatar
yep, ive had that happen, the HB servo horns go on easy and come off easy and i won a big race without the screw in hahah i was just one lucky person lol and i never use lock tight, and i dont even use the screws that come with hitec, i re-thread mine and use a regular screw .... not advised though lol
Old 08-29-2010, 10:14 PM   #94
tc5 man's Avatar
retread yea, i wont be doing that but i always lose the stock screws that come with, the servos i always end up making a homemade screw to fit the servos lol.
Old 08-29-2010, 10:27 PM   #95
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
they usually go bad at 2-3 gallons... i hope you are one of the ones that have great luck with them
Hope so too! Don't want $110 going down the drain. Time will tell!
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 08-29-2010, 10:28 PM   #96
jmaxey51's Avatar
the hitecs have a what i call "bastard" screw, they have a different thread pattern than anything else, its a freakin pain to find one if you loose one so thats why i re-thread them
Old 08-29-2010, 11:44 PM   #97
merdith6's Avatar
Default Yep
I don't understand why they don't use a regular screw, but If you buy a pack of HPI screws that fit with the 2mm allen head and put just a small ammount on the screw it will be fine, and use the Blue alluminum horn from hitech it works great. On the throttle plastic horn use a small washer under the screw and it will hold good....
but rethreading the servo is a really great idea, Nice work man....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 08-30-2010, 09:04 AM   #98
Arco's Avatar
This is the replacement screw.
OverdriveRC.com
"Promote and Support"
Arco is offline   Reply With Quote
Old 08-30-2010, 09:37 AM   #99
I run the 7940TH's in Buggy unregulated. They run great, I need super fast servos and these do the job.
I have also ran them in Truggy, still no issues, more then enough torque with lipo.
Losi 8T 2.0 - Novarossi P5 Modded - JR 9100HVS' - Odonnell Fuel -
Mugen MBX6 - Novarossi +4 Modded - Hitec 7940TH's - Hudy Tools
Andy Z is offline   Reply With Quote
Old 08-30-2010, 12:07 PM   #100
Decided to order a 7950 and see how it works in the truggy
itbvolks is offline   Reply With Quote
Old 08-30-2010, 03:41 PM   #101
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
well if i set it at 0 on the trim before i put the servo horn on it should center straight but i goes the left when i press on the alum horn.
the teeth look fine on the horn and the servo.
That's not how it works bud. Every servo horn is different. Every vehicle is different. Every linkage is different, Etc... You have to adjust the trim to suit. That's not a centering problem, or a servo problem, or even a problem. User error.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-30-2010, 03:46 PM   #102
Please DO NOT send your servo in. There is nothing wrong with it, you're just not using it properly.
The screw is an odd size, but not at all hard to find. You need a 2.6x8mm screw.
Here is a VERY cheap pack of 12. Probably last you a lifetime. No loctight needed.
http://www.amainhobbies.com/product_...-Head-Screw-12
-Koby Kubrin-
Old 08-30-2010, 03:47 PM   #103
That's actually not the right screw. It may work, but the size you really want is 2.6x8mm not 2.5.
-Koby Kubrin-
Old 08-30-2010, 04:12 PM   #104
Arco's Avatar
They fit perfect, been using them with zero issues.
I bet they are identical other than a mistake on someones wrapper.
I'll add them to tomorrows order to see what's what.
OverdriveRC.com
Old 08-30-2010, 04:16 PM   #105
No, 2.5 and 2.6mm screws ARE different. Not by much, but they are different. I learned the hard way that it really is better to have a 2.6mm screw in Hitec servos. The 2.5's will work fine for awhile, but eventually they will start to back out on you if you don't use loctight.
-Koby Kubrin-
>>>NEW HPI Savage XL w/ Big Bores, JR 8711 steering servo and more.. JP116 R/C Items: For Sale/Trade 70 04-21-2009 02:40 PM
I Need a Good Steering Servo insanewulf Nitro On-Road 52 12-22-2007 05:19 PM
steering servo whats the best on a budget? rltanner Nitro Off-Road 41 09-26-2007 05:06 PM
Best 1/8th scale steering servo?? cjaeckel Nitro Off-Road 39 06-15-2007 05:20 AM
