steering servo
#76
ive had some pretty bad wrecks and ive hit another truggy at wide open throttle head on down the straight (bc he was going the wrong way ) and never had any problem... your center problem isnt with the $50 or cheaper servos is it? because i have had centering problem on those... but with the 79(whatever number) there hasnt been any problem. futaba is good servos, but i need more torque than they offer.
#77
Never had one little hint of a centering problem on any of my Ti gear Hitec's. I've run 59XX series and 79XX series. Not one little issue.
Futaba's are good servos too, but nowhere near as tough as Hitec's.
Savox servos(Orion)... Well I have no experience with them, but I've seen some big name Savox sponsored racers running Hitec's for steering. So I'd venture to say that Hitec's are better.
#78
no its the, 7954 sh servo its just when im ready to put the servo horn on it wont center at a 90 @ angle like it did before but the wheels center fine.
god no i stay away from the cheaper diginal hitec servos they sucked.
#81
na my hitec, and futaba servo dont twitch at all im using a futaba 3pk with the speckum module.
#82
no i set it at 0 on the trim it still does it.
#86
#87
I have a jr9100s that twitches like crazy when I let it sit straight... is that the same centering problem you guys are talking about?
#88
#89
all servos ive had has done that because the teeth arent perfect to your horn... also what ive learn is turn the steering all the way both ways a couple of times before putting the horn on to make it center right.... and problems finding center is when your driving and it wont make the wheels straight after you've adjusted it all up. meaning one time it will pull to the right and you fix that then the next time it will pull to the left, if you know what i mean? all servos you have to adjust them with 99.9% of the servo horns... i hardly ever am able to leave it at 0.
#90
i adjust the, trim so i will track straight it does actually somewhat go to the left but than again i could use sub trim. na i cant leave my at 0 ethier now.
i wish i can find the gears for it i know that whould fix it .
the wheels do center back when i turn left and right .
