Old 08-25-2010, 11:11 AM   #16
JASON671's Avatar
Trader Rating: 50 (98%+)
I will try a softer clutch setup, the track is high/med traction. real tight and tech well sorta. last weekend i ran out of fuel in exactly 7 1/2 minutes. I will try these changes and see the difference. but the motor only has exactly one gallon on it and i just started to lean it out. temps are at 210/215.
JASON671 is offline   Reply With Quote
Old 08-25-2010, 11:12 AM   #17
deadmancourt's Avatar
Trader Rating: 11 (92%+)
try running a 7mm restrictor in truggy and
6mm or 6.5mm in buggy....DONT JUST LEAN YOUR ENGINE OUT!...but you MAY be a TAD rich somewhere! but if YOU dont think so,then try the restrictors
Rob Schneider
Special Thanks To:
S&W Fuel~Agama Usa/HobbyProUsa.com
RcRenew.com and TritonRc.com~Lucky7~Eazyrc.com
Venom-Group~Upgrade-Rc and TrackstarRc.com
deadmancourt is offline   Reply With Quote
Old 08-25-2010, 11:16 AM   #18
JASON671's Avatar
im a little rich on bottom still. i tested with a 7mm and will try a 6.5 tomorrow. sucks i have to go to work now. Im gonna sneak my motor and clutch parts in my lunchbox and change the clutch setup at work.
thanks fellas,
later!
Old 08-25-2010, 11:19 AM   #19
Maximo's Avatar
Tuning ! its all in who's turning the needles.....runing a tight idle gap and a properly balanced LSN is a huge factor...But to make a motor stable with a tight idle gap you need to have a good plug and a solid running fuel.....Just this weekend I had a fellow running his engine at 285 and making 9.5 mins on a Picco Boost...after changing to a cooler plug and readjusting the needles we had 240 degrees and 13:48 runtime....with the proper tuning and setup many engines are capable of a 10 minute pitstop, but it requires some finesse and knowledge to achieve..... Also don't discount fuels, some fuels will give a fair bit more runtime then other fuels...
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 08-25-2010, 11:30 AM   #20
Originally Posted by cjm1126 View Post
clutch and other varibles never made much difference in fuel economy from my experience, it takes the right engine and pipe combination with a smooth trigger
sorry bud, but Im my experience it all makes a difference, all the factors play a huge roll in run time.
plus I think i have done quite abit of racing this summer and I pitted for a bunch of people with all kids of engines and set ups. I have only seen one driver that could pit at the 10 min mark if needed.......He was running RB engines and I know his stuff is DIALED......
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-25-2010, 11:46 AM   #21
Chris Peralta's Avatar
The car it's self also plays a huge part, some cars have a much more efficient drive train than others. Some people don't do much maintenance and even the cars that have an efficient drive train will suffer due to bound up bearings. I have also seen guys that clean all grease out of bearings and run all metal shield bearings in the drive train and hubs and still not get 10 minutes with a super free drive train. LEAN her out, I really doubt there is an engine out there that's going to run for 10 minutes at 210 degrees. I don't own a temp gun, but I am sure 250+ is quite normal for me when tuned for max run time.
Chris Peralta is offline   Reply With Quote
Old 08-25-2010, 12:41 PM   #22
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Ninjas arent really known for their run times, are they? Search some previous threads on here for engines known for run time and you'll have that much of a head start when you tackle......
Originally Posted by token View Post
depends on alot of things. People act like its all in the engine.... no no no
Engine
Tune
Pipe
Header
Clutch
TRIGGER FINGER
Control
Keeping your line
Smoothness
Fuel
Outside temp
Altitude
cpaurl
rallyebmx is offline   Reply With Quote
Old 08-25-2010, 12:48 PM   #23
with a nova +4, 6,5mm restrictor and the 9901 pipe you will get 10minutes quite easy, because it's capable of around 13-14min stops....
Martin.S is offline   Reply With Quote
Old 08-25-2010, 12:51 PM   #24
Trader Rating: 163 (100%+)
where i race atleast half of the guys in the amain pit at 10 minutes including me
cjm1126 is offline   Reply With Quote
Old 08-25-2010, 12:56 PM   #25
My Ninja goes 12:23 minutes on a tank - in a truggy - using OS P3 plugs - at only 96 degrees Celcius (200F i think). So I can easily go to a P4 plug and lean it out and go even further.
10+ min in buggy with Ninja is common (here in Denmark atleast).
The important thing about the Ninja, is that you use the Ninja EFRA-2042 (or OS T-2060) exhaust - without it, it wont go far on a tank of fuel.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 08-25-2010, 12:57 PM   #26
slow coach's Avatar
EPA
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 08-25-2010, 12:59 PM   #27
wingracer's Avatar
Trader Rating: 23 (100%+)
You have all missed the most obvious and the biggest factor. THE TRACK.
A really smooth, super fast, high bite track and no one fast is going to be going 10 min. Oh it can be done, but this track can take all the HP you can give it. Better results will be had by going balls to the wall and running much faster laps that will more than make up for the time of the stop.
Slick, tight, bumpy as hell blown out track and even the most fuel guzzling motor should be able to go 10 with smooth driving.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-25-2010, 12:59 PM   #28
Send a message via MSN to André costa
i use a plus 4 in buggy and get 11min +, 7mm restrictor M3 bow tires and losi silver springs and alumin shoes temp 248 or 257
sorry for my english
André costa is offline   Reply With Quote
Old 08-25-2010, 01:08 PM   #29
snowman6869's Avatar
Trader Rating: 17 (90%+)
Send a message via Yahoo to snowman6869
Yes they are.I've gotten 12 minutes on mine but I usually pit at the 9-10 mark and still have fuel left.
CASTER RACING TEAM DRIVER casterracingusa.com
ALPHA ENGINES
SPECTRUM
SAVOX
LUCKY7 RC FASTLANE GRAPHIX
snowman6869 is offline   Reply With Quote
Old 08-25-2010, 01:08 PM   #30
+1 something I was going to say
ALPHA ENGINES
SPECTRUM
SAVOX
Hotbodies Ve8 Thread joelwhite Electric Off-Road 13618 04-02-2017 06:46 PM
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 07:32 AM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 08:24 AM
10+ minutes Engines List cheapskate.brok Nitro Off-Road 77 06-24-2009 08:57 PM
