decent club racing motor??
#16
it says to use a max of 25% do i need to shim for 30% and i have a new gallon of 20% but i run 30 will it hurt in the long run if i used the 20 to break it in ,and i have a jp3 pipe at the moment will that be a good pipe or should i get the 053 its a smaller tight track with good size jumps ' but not alot of run up on them
i race at rescue mini speedway
you can use 20% and, it runs fine but 25 % it runs better yea i would add a shim if you use 30 %.
well what i been told, my a racer is if you broke it in with a certain amount of nitro than it will run best with that.
i think a 53 pipe whould, be better actually because when i used the 86 pipe on a small techinal track it was hard to hit some jumps.
#17
yes sir
it does NOT need an 086 pipe at all uness you have LONG straight aways. mine struggled more with the 086 than an 053!!! i wasnt able to make jumps out of the turns with the 086 but made them with ease with the 053, gave it a little more bottom AND gave it 2 min more run time. i got over 10 min a tank with 053 versus barely making 8 min with 086. if your track isnt wide open then 053 is all you need. i just do not see why everyone needs all this top end power when 90% of the time you cant even get to it. this isnt a drag race guys, just saying
also the GRP is way faster than that engine. youll probably want your GRP at smaller tracks.
then you could gear up a tooth on a larger track, but if it's small or medium then run it how it's normally geared with the 053...short round header....
#21
O'donnell 99 or McCoy 8. i liked the OD 99 better. also you dont have to shim it for 30%, it wont hurt it at all or shorten life. they recommend 25% tops but thats mainly for break in. i ran 30% with no trouble with the same engine and so does everyone else. i know someone with 8+ gallons on theirs running 30% with stock shims. 20% is going to be super slow trust me, i tried it lol
#22
#23
if your using 30% add a shim and use a cold plug or a meduim plug.
if 20% a, meduim plug and when it gets cold outside use a hot plug.
if you choose, to use 20% the shimming on it is for 20% to 25 % just like my rb is.
sorry double post.
#24
while i do agree that 20%, can be too slow but i think depends on how much oil is in it i know my, ebmods fuel is about 10% and byrons 20% is 12%oil.
i think its fast enough .
#26
yea i know i just, messed up lol as for the nova.21 bf dont having power stick a higher tooth cluchbell and tell me what you think i used a 15 tooth when i ran it on my buggy wow !
i havnt seen, a turbo conversion kit for it but maybe the 4 port nova turbo button get fit it.
#27
EB mods is almost the exact same as byrons, my engine runs hotter with EB mods, over priced fuel IMO. also i did test with 30-9 and 30-11, my engine was faster and ran cooler with 30-11 but my dads engine ran cooler with 30-9. but with these 3 port Nova, you NEED 30% or woull be WAYYY under power. ive owned 2, mod and stock, you need ever bit of power possible, these arent very powerful. 20% is to low , 25% will be better, i wouldnt run anything lower than 25%...
#28
#29
also on plug choices, the colder the plug the smaller the tuning window will be
#30
its the same persentage oil as byrons fuel ? i guess the ebmods website is lying then. i might me racing, this sunday and, i did finally get my engine running better than it was so i will see how fast it is .
yea it does cost more, than byrons fuel but the main building is in pa and a lot of guys run it at my track. i just hate to competly retune a engine to run 30 % .
but doesnt 30% have a smaller tuneing window ? im not that good at tuneing man.
and i do have a lot of fuel left in my 20% gallon.
