Old 08-22-2010, 05:15 PM   #1
Trader Rating: 22 (100%+)
Default What plug for Novarossi Plus 21-5K?
Anyone know what plug works good for Novarossi Plus 21-5K? I'm using O'donnell 97T with Byron Race Gen2 30% fuel. Engine turns on but soon as taking off plug heater, they shut off. I have no idea on 8th buggy plug.
Losi 8ight-T 2.0--RB WS7
Slash 4X4--Castle Sidewinder SCT
rcs950racer is offline   Reply With Quote
Old 08-23-2010, 02:12 AM   #2
If its the 5k then it takes standard plugs. If its the 5kt then it takes turbo plugs.
If its turbo the 97t is fine. Standard i would run a OD 77. If it flames when you pull the igniter off your plug is most likely bad. If you replace the plug and it continues to do the same then you are way too rich on bottom.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 08-23-2010, 02:32 AM   #3
merdith6's Avatar
Default well
I had that happen once or twice in a turbo style Nova. Take the plug out, and remove the head button and clean it really good with a q tip and some denatured alcohol or whatever, especially down in the threads and in the taper area. "While you have the head off go ahead and clean the inside of the engine and carb." I would bet there is dirt in there, the head button, causing it to not seal...Put a new plug in it, 97t is perfect. and tighten the plug pretty good. Did you put an OS glowplug in it before? Sometimes that can distort the taper causing leaks, they don't really fit the Nova engines.....
Check the clutch too. the springs may be weakened or something that is hanging up....there is always a reason an engine won't run, and it can be irritating to find the cause sometimes....Be patient...and take it one step at a time......
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 08-23-2010, 07:29 AM   #4
mblgjr's Avatar
Trader Rating: 86 (100%+)
Try the OD77t or Novarossi C6TGC, or C5TGC.
It should run on any of those.
Do NOT put an O.S. plug in it.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 08-23-2010, 01:24 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
try to replace plug first , if you are good at tuning try to tune it in , if not find a good local engine tuner in your area to help you out .
the 21-5k was/is a great engine , loved it in truggy
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-23-2010, 02:11 PM   #6
I replace the plug to new 97T and still this happens. I got help from good local racer.
Old 08-23-2010, 02:21 PM   #7
cordarrow's Avatar
Trader Rating: 17 (100%+)
OK...with the glow plug igniter still attached to glow plug...how does it run?
Can you accelerate the motor?
cordarrow is offline   Reply With Quote
Old 08-23-2010, 02:28 PM   #8
Yes but sometimes when I accelerate to max too fast, they shut off.
Old 08-23-2010, 02:30 PM   #9
cordarrow's Avatar
This is a good motor with good compression?
Old 08-23-2010, 02:48 PM   #10
cordarrow's Avatar
If it's in OK shape....and you can make it HERE
on Sunday....we'll sort you out.
Great bunch of guys...always willing to help.
Old 08-23-2010, 04:38 PM   #11
Well after heating up engine with hair dryer, engine wont stop when ever I pull off plug heater. I guess that was heating issue. Finally buggy runs without plug heater!
Thanks for helping me out guys.
Old 08-23-2010, 05:40 PM   #12
I run a OD100 plug 30% byrons and a msr1005 pipe header combo
jet flyer is offline   Reply With Quote
Old 08-23-2010, 08:52 PM   #13
houston's Avatar
so the engine is new?
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
NovaRossi .21 Plus 21-5 review rczonecentral Nitro Off-Road 216 04-11-2009 09:35 PM
Glow Plug for Novarossi FMS franklucas Nitro Off-Road 9 03-08-2009 10:54 PM
Novarossi 367 cota348 Nitro Off-Road 48 08-21-2008 09:22 AM
Novarossi ,best choice? sac Nitro Off-Road 37 04-06-2008 09:35 PM
