Old 08-21-2010, 05:38 AM   #1
Default help please. flywheel/
Ok. This is going to be hard to describe but i will do my best. I have a new jpx .21. Well, after i tighten the flywheel it has a lot of resistance when i turn it. THe piston is moving up and down, but it's almost like i can feels all the balls in the bearings dragging. Maybe like the flywheel is rubing up against the crank case? It's hard to explain, but its only when i tighten it, and it's alot of jaggy resistance.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-21-2010, 05:51 AM   #2
2fst2c's Avatar
Trader Rating: 114 (100%+)
I'd go with that..Put a different collet on or more shims behind it and see what happens.
2fst2c is offline   Reply With Quote
Old 08-21-2010, 05:52 AM   #3
anyone? Is it the bearings not being seated properly?
Mugen
Old 08-21-2010, 05:59 AM   #4
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
+ 2
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Old 08-21-2010, 06:01 AM   #5
Trader Rating: 49 (100%+)
+3.... Put a shim behind the collet
cleblanc is offline   Reply With Quote
Old 08-21-2010, 06:12 AM   #6
that's not it.
Mugen
Old 08-21-2010, 06:15 AM   #7
it's almost like when you tighten the flywheel, the outer edge of the crank is hitting/rubing on the outer cage on the rear bearing. I cannot describe how frustrating this is.
Mugen
Old 08-21-2010, 06:23 AM   #8
Suspended
Trader Rating: 202 (96%+)
so you did try a new collet?
inferno13 is offline   Reply With Quote
Old 08-21-2010, 06:27 AM   #9
bad front bearing.
Mugen
Old 08-21-2010, 06:39 AM   #10
Suspended
bad front bearing.
really? your NEW engine came with a bad bearing?
Old 08-21-2010, 06:42 AM   #11
yup. took the crank out and the balls are catching inside the bearing. I have been looking foward to running this motor for 2 weeks for this weekend and a BAD bearing. UNBELEIVABLE. I thought ITALIAN motors were SO HIGH quality.
What a joke
Mugen
Old 08-21-2010, 07:46 AM   #12
GRANPA 67's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to GRANPA 67
What a joke
Return to sender,I say, excellent build quality,but use cheap bearings??
ASSOCIATED RC8B3 , NINJA B02 , HITEC, SANWA, AKA , DHAWK RACING
ASSOCIATED RC8T, NINJA B01A , HITEC, SANWA, AKA, PROLINE , AVID
LOSI 5IVE, ZENOAH 29cc, HITEC, SANWA, DDM, TEAM GONADS, TURTLE RACING
SHUT THE GATE ON THIS ONE , IT`S THE DUCK`S GUTS , IT SUCK`S NITRO..........
GRANPA 67 is offline   Reply With Quote
Old 08-21-2010, 07:56 AM   #13
it's been taken care of. I do agree that picco has really good quality stuff. Better then the o.s. i run. Just one of those things. Just sucks it happened ot me.
Mugen
Old 08-21-2010, 02:57 PM   #14
wingracer's Avatar
Trader Rating: 23 (100%+)
Tough break dude but it can happen. Bearing manufacturers make millions of the things and a bad one is going to slip through every now and then. Glad to hear it's being taken care of for you.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-21-2010, 03:23 PM   #15
houston's Avatar
Trader Rating: 91 (100%+)
try a new collet first , sometimes an improperley angled collet/flywheel will pinch the bearings together and wear them out very very quickly
not all italian mills are the same
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Flywheel help please? Ma-Deuce Nitro Off-Road 8 11-01-2008 07:06 PM
New Mugen MBX5R engine selection help please pracy Nitro Off-Road 26 05-11-2008 01:21 PM
Need help please with Sirio XER987 Nitro On-Road 9 03-25-2003 03:46 PM
