Old 08-20-2010, 11:29 PM   #1
Default balloon
hi why does my tires on my xb8ec go like a ballon?? diff oil 7/5/3
thanks
africa is offline   Reply With Quote
Old 08-21-2010, 04:27 AM   #2
try a heavier oil in the centre, and by heavier I mean 3000 or more up from what you have
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 08-21-2010, 04:29 AM   #3
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
If its electric try 5/7/4 or 5 or just change center to 7 and see if that makes a diffrence. Electrics will always ballon front tires a lil but a thicker center add more rear drive. The balloning isnt really somthing to worry about if its not bad and set up feels good leave it alone.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-21-2010, 04:44 AM   #4
Well if you add more rear drive, you are not diffing the power to the front as much are you? that is the problem, specially if he's got a hight turn motor.
Rui Almeida
Hamilton, Ontario
CANADA
Old 08-21-2010, 05:47 AM   #5
thanks not elec has os 21 vspec
Old 08-21-2010, 12:31 PM   #6
O you are running a nitro and the front is balloning i ran a 808 and my setup was 5/4/2 it was perfect.
Old 08-22-2010, 08:15 AM   #7
99problems's Avatar
Long story short use a leather punch to put 4 holes(one on each side of the circle) on each tire to allow the tires to breath. Its just pressure building up from the friction of the tires touching the surface.
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Old 08-22-2010, 12:55 PM   #8
+1 that could be a major reason to balloning ur not letting the air escape the tire, why didnt i think of that!
WHY DO LIPOS BALLOON COBRARACING Radio and Electronics 12 06-06-2010 08:34 AM
Balloon Shock Covers 1NitroDude Rookie Zone 8 12-12-2009 08:11 PM
SOS: One of the Rotors of RC Balloon/Blimp is not working ran001 Singapore R/C Racers 13 07-23-2009 07:30 AM
