Old 08-19-2010, 08:24 PM   #1
Default Camber link adjustment ?
I finally feel like i am getting good enough to tell a difference in car setup , so i want to start making small changes to see if i can get a better setup . I have the basics such as shocks & diffs set up pretty good but am wondering what moving the camber links around on the towers does . If i want more rear traction should i move it down , up or in or out ? Is there some reading material on set up i can get ? Thanks for the help in advance .
romax is offline   Reply With Quote
Old 08-19-2010, 09:28 PM   #2
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Might not be a 100% respnse to ur ? but DRAKE has some set up tips on youtube heres a few btw it dont have to be a losi to follow these easy tips!
http://www.youtube.com/watch?v=H99PKqsUZjA
http://www.youtube.com/watch?v=P6WHG...eature=related
http://www.youtube.com/watch?v=VjxxeJgrq5c
http://www.youtube.com/watch?v=BWvdz...eature=related
hope Drake helped you out!
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-20-2010, 04:09 AM   #3
FLHX1550's Avatar
Camber links in general = the shorter the link, the more camber action (how much camber changes thru the suspension cycle), moving up or down changes when the camber cycles.
It's always a comprimise, and takes testing to know the feel. Personally I like as short of a linkas I can, usually as low on the tower as I can. This makes the back of the car very aggresive with grip on the power, and makes it feel good in the rough. But if it is too short, the car does snap allot if grip is in-consistant.
General rule of thumb, shorter on rough, higher grip - longer on smoother, low grip
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 08-20-2010, 12:30 PM   #4
So if i am on a loose track with inconsistent traction i should try moving the links in on the towers . Should i put it up , down or middle ? Also should i use the outer hole on the hub ? Thanks for the help guys .
Old 08-20-2010, 02:07 PM   #5
When you do that ur camber links will be all out of wack. Honestly i would run stock holes and get a camber gauge and gor about -2 or -3 degrees and try it out. If your not getting bite try diffrent oils in diffs and tires.
Old 08-20-2010, 04:26 PM   #6
Trader Rating: 119 (99%+)
Do yourself the biggest favor ever. Go to rcamerica.com and download the hudy set-up book. This will tell you both the pros and cons for every single set-up change you can make. This book IS THE BIBLE for 1/8 scale offroad
skoalisbad4me is offline   Reply With Quote
Old 08-20-2010, 04:33 PM   #7
pyromania's Avatar
Trader Rating: 18 (100%+)
Why run only the stock set-up? Those hole are there for a reason. I dropped my qualifying time by around 10 sec by dialing in my own set-up and another 10 sec when using the correct tires. Start to mess with your set-up and find the sweet spot where you really like how the car drives.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 08-20-2010, 04:37 PM   #8
Thanks a lot ! Just what i was looking for .
Old 08-20-2010, 04:40 PM   #9
I have camber & ride height gauges & i would re set camber after moving the camber links . I have the car really close , just looking for a slight edge over the others .
Old 08-20-2010, 04:43 PM   #10
pyromania's Avatar
Yes, after any camber link adjustment, reset your camber.
Jesse Carrillo
Team Driver For:
Old 08-20-2010, 04:48 PM   #11
Oh yea , that's what i was saying in reply to nitro saying my links would be all out of wack .Thanks
tc5 roll center and camber link relation question poochy Electric On-Road 18 12-07-2008 12:17 PM
Which is more important? Upper link length, or roll center crazyjr Electric Off-Road 6 09-21-2007 01:59 PM
What the ?...with Camber links timmey Electric Off-Road 6 08-30-2006 03:44 AM
Setting: Droop VS Camber link position Alvin Electric On-Road 55 01-13-2002 09:21 PM
