Old 08-19-2010, 04:27 PM   #1
nmt6789's Avatar
Send a message via AIM to nmt6789
Default Idle speeds up even though I am turning it to go slower?
Any idea why when I turn the idle screw on my Losi 454, the idle goes faster instead of slower even though I am turning it in the right direction?
nmt6789 is offline   Reply With Quote
Old 08-19-2010, 04:31 PM   #2
jonski's Avatar
Trader Rating: 233 (99%+)
You are running it too lean.
jonski is offline   Reply With Quote
Old 08-19-2010, 04:35 PM   #3
Screwing it clockwise will raise the idle. Counter will lower it. Set your gap to about .5mm to .7mm. Then leave it alone. If it is still too high your low end is lean. It should idle alittle high after the motor is cleared out for about 8 seconds or so then drop to a low idle and load up again.
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 08-19-2010, 04:37 PM   #4
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
+1 and set end points
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-19-2010, 04:58 PM   #5
Fd2k's Avatar
Trader Rating: 25 (100%+)
This is what Ron from Werks Engine explain to us Werks engine users to do if tune if off. It might work for you. If you want give it a try.
a) Set idle gap with idle stop screw to roughly .5mm.
b) Set HS and LS to flush with the end of the housings.
c) Fire up engine and blip throttle to warm up then let come back to idle. Adjust LS needle to get smooth steady idle. Leaner = higher idle, richer = lower idle. Adjust this until you get a smooth, steady idle. Do not touch the idle stop screw only use the LS needle!
d) Toss the car on the track and adjust the HS needle to get the top end performance that you want/need.
e) Finally pull the car in and adjust the LS needle one final time (probably richen it) to bring the idle speed back down and you are done.
That's all that you should have to do and you should be done!
Losi 8ight 3.0 / Novarossi P5 / Novarossi Pipe / Hitec servo / GunHill Track ( Ft Knox Park ) / Spektrum / Werks Fuel / Proline /
Fd2k is offline   Reply With Quote
Old 08-19-2010, 06:24 PM   #6
koopesv's Avatar
Trader Rating: 18 (95%+)
I think it might be your clutch shoes or springs are worn
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 08-19-2010, 06:36 PM   #7
tc5 man's Avatar
that sounds good but , i think all you need to do is richen the low end 1/4
cw. and than do the pinch test
or it could be a broken spring or the carb could be stuck maybe.
Old 08-19-2010, 07:02 PM   #8
Another possibility, if the clutches are worn or not installed correctly they will do that and when u mess with the idle it will also cause the clutches to ingage in hight rev's, might be somthing to check out.
Old 08-19-2010, 07:24 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Possibally an air leak.
Old 08-19-2010, 07:39 PM   #10
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
might be anyway do u race at rescue frank i c u on the rescue forum i thought once
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
