Old 08-19-2010, 12:47 PM   #1
nmt6789's Avatar
Send a message via AIM to nmt6789
Default Setting up starter box?
I bought a Losi 8ight-T RTR with the starter box and I can't quite figure out how to get the starter box to line up. I had it lined up pretty well and then the mounts came loose and I can't get the flywheel to line up.
Does anybody have any tips for lining up the flywheel and the wheel on the starter box. It is extremely frustrating.
nmt6789 is offline   Reply With Quote
Old 08-19-2010, 12:54 PM   #2
tc5 man's Avatar
i whould say get the losi eight box, and you dont have to worry about setting it up it will line right up with the eights.
but do replace the stock motors, with 2 traxxas titan 21 t motors but you do have to cut the motor shafts down a bit to line up .
tc5 man is online now   Reply With Quote
Old 08-19-2010, 12:55 PM   #3
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Easiest way to line ur box up is loosen all the pegs and take engine out of ur car then line it all up like that by the slot in the chassis. Much easier than with engine in, i do all mine with engine out.Make sure you alighn it straight though with the chassis.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-19-2010, 01:12 PM   #4
nmt6789's Avatar
I have the 8ight box.
Old 08-19-2010, 01:13 PM   #5
tc5 man's Avatar
the black one or the red eight box ?
Old 08-19-2010, 01:13 PM   #6
Drusillus's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Drusillus Send a message via MSN to Drusillus Send a message via Skype™ to Drusillus
..... I never thought of doing that..... I feel really dumb.
Drusillus is offline   Reply With Quote
Old 08-19-2010, 01:20 PM   #7
yeah i use to do it with engine in and my luck was teribble and i had a friend do it for me and he was doing it with engine in aswell but all he did was look into the flywheel slot. After that i decided i will take the extra 5 mins to take my engine out and alighn it all then put my engine back in. Now that i have quick change its even easier lol. JUST MAKE SUE U TURN ON THE BOX AND I SPINS FREELY WITHOUT HITTING THE CHASSIS WITH THE ENGINE OFF OR ELSE ITS A PAIN IN THE REAR, because some times the car will slant up and the chassis will rub the wheel just a lil and can hurt the motors in the box.
Old 08-19-2010, 01:55 PM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Having the engine out is a MUST. Makes everything much easier. I like to adjust the front pegs so that the wheel lines up correctly and tighten them down. Then adjust the rears to hold the back of the car. Works every time.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-19-2010, 01:58 PM   #9
Way easier isnt it lol i dreded doing it with engine in it was a pain.
Old 08-19-2010, 02:25 PM   #10
wallot's Avatar
it is not a must.
takes just few moments even with the engine on unless you are vision impaired
loosen the pegs, slap the car on, tighten the pegs so the car can't move move
front pegs right behind front arms as close to chassis as possible.
rear pegs in front of the rear arms if it is needed to prevent car from moving forward. if not just to prevent the chassis from moving sideways.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 08-19-2010, 03:10 PM   #11
Originally Posted by wallot View Post
it is not a must.
Sounds complicated when u can just take engine out and u know its right the first time. I use to do that and it was a guessing game, i have pernt wheels from it just being a lil croocked its no good.Maybe ur lucks better but mine not so much.
Old 08-19-2010, 03:27 PM   #12
It's SOOOOOOOOOOOOOO much easier with the engine out! I don't like the idea of the pegs sitting against the arms either. I set mine up so that they fit the chassis. Front pegs are as far toward the center of the car as possible, sitting in the narrow spot of the chassis right behind the front clip. Rear pegs braced against the back edges of the chassis. I have it setup so that anyone can start my cars. It only fits one way and that's the correct way. I've actually had the starter box "stick" to the ca when lifting it off. That's how tight the pegs are on the chassis.
-Koby Kubrin-
Old 08-26-2010, 07:19 AM   #13
Dr. Evil's Avatar
Talking Try this as an added bonus
Excellent suggestion about removing the engine. I did mine with the engine in it
just because the engine is not always exactly centered depending upon which
clutch end bell you use. But, that way will get you to work.
After doing the setup, I suggest taking a black marker and tracing the base
of the setup pins. When you are all done, take the pins off and writing what
buggy/truggy/truck those circles are for. When you you are done with that
apply some clear Heavy duty packing tape (Just enough to cover the circles and
writing) to the box. This way, you can later move the setup pins for another
vehicle and you won't have to worry about having to try to setup the box
all over again. Do this for different vehicle and you can change pretty quickly
from one vehicle to another.
Dr. Evil is offline   Reply With Quote
Why won't my starter box turn my engine over? sokar Nitro Off-Road 18 07-17-2009 10:46 PM
8ight starter box Jonro Nitro Off-Road 69 03-19-2009 06:44 AM
