Exhaust Pipes. Which Numbers Mean What and what will it do for my motor??
I have a question.
There are numbers like EFRA 9886 and so on and so forth.
Does anyone have a list of all the numbers and what they do for motors.
Several New motors have come out and they don't work with the pipes I have.
Example, Ofna has a P3 pipe which works wells with some motors, but doesn't
work with others. It's not a numbered pipe like the EFRA mentioned above but,
there are others that are.
Looking at Amain, there are the following
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
And So on and So on.
Help. What does it all mean???
Can I make a science out of it??
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
I have a question.
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
Efra 9886 is an 086 pipe designed for top end performance. It works killer on most 5 port engines. I run the Dynamite version on my P5XLT and it hauls azz!
2013 Werks and a few other brands is a good all around pipe with excellent low-mid-high end performance. Especially on the Werks B5.
The 2035 Thunder Tiger/Associated is a good 3 chamber mid range pipe that has good all around performance on certain engines.
2050 Losi/OS/Axe Rossi is a solid mid range pipe and works good on V-Specs and some other motors
Dynamite 053 is a great mid rage pipe as well
Dynamite 007 is a bottom end pipe and works good on most 7 port motors that I've used mine on.
2039 Thunder Tiger is a short 3 chamber pipe entended for top end performance.
Most pipes are designed for a specific power range and work better on certain engines. It would benifit you to ask what pipe works well for the engine that you have or the engine that you're looking to purchase.
pipes
What pipe works best with the RB 5 port motor. I was told the os2050 is the one to have but not sure.
Mike
Mike
What about the Werks B7 engine? Which pipe to choose?
Ronny
Ronny
I really like the dynamite platinum series tuned pipes. They have pipes for each rpm range available and can be bought for cheap on ebay. Just supply your own header. The hard adonizing matches the parts on my buggy and truggy and looks great. They also reinforce the stinger so they won't break easily. I've been impressed with the performance but i run go engines.
I have a question.
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
2013
2035
Losi 2050
Dynamite 053
Dynamite 007
Thunder Tiger 2039
Basicly a pipe is designed for a type of engine with which the manufacturer thinks he can use on big (EFRA/FEMCA/ROAR) events. The performance of a 2-stroke engine stands or fals with the choosen pipe and one pipe can make one engine a beast and the other a disaster.
The choice of a pipe cant go wrong if you find out what loplevel drivers with that engine drive or what others are using.
If you are on a club you can ask fellow clubmenbers to try some pipes of them and find out which one you do like.
Tricky statement.....
