Old 08-17-2010, 05:48 AM   #1
Default proline mbx6t bulldog lid for a Xray XT8
does any one know if the mbx6t proline bulldog lid fit the xt8 09 spec? cheers
neil73 is offline   Reply With Quote
Old 08-17-2010, 06:22 AM   #2
yup.....front body post holes line up about spot on.... youll need to move the rear body posts down on the tower and dont trim on the side pod trim lines. you need to leave a little extra material
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-17-2010, 08:09 AM   #3
nitrotrippertje's Avatar
I dont see any reason why it would not fit just take your time measuring and it will fit nicely.
I got one fitted my X2 CRT and fits really nice.
nitrotrippertje is offline   Reply With Quote
Old 08-17-2010, 10:01 AM   #4
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
i know the 6t body fits xb8 great so im 100% sure the 6t bulldog fits i ran xray buggy and used mbx6 bulldog and fit perfect the specs are very close on each company.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-18-2010, 04:12 AM   #5
thanks heaps,.... nitrotrippertje i take it with those tryes your racing grass or astro???
punkracer24,.. "and dont trim on the side pod trim lines"??? side pod?? rear wheels???
i dont think the xt8 has the ability to move the posts down..
Old 08-18-2010, 04:21 AM   #6
blade954's Avatar
Trader Rating: 23 (100%+)
Neil you have to drill holes in your rear shock tower (lower) to make the bull dog body fit. See the Mugen shell up in the pic with the body pins at the front . This is why i went the RC8T shell as the bonnet is a different shape and works better with the body pins....
See the difference in Jakes to the top pic... Not saying its not going to work but the RC8T defiantly fits better. You have to remove the rear shock tower and drill it on the drill press to get a nice neat job.
blade954 is offline   Reply With Quote
Old 08-18-2010, 04:31 AM   #7
Yes i run these only on grass or astro.
You have to drill one or two new holes in the rear shocktower.
Old 08-18-2010, 11:22 AM   #8
Jammin57's Avatar
Trader Rating: 120 (100%+)
The mbx6t punisher and bulldog bodies will both fit. You can actually use the stock rear body mounting holes and posts on the tower but it will look better if you will lower them down some I used the 6t rear body mounts and mounted them lower on the tower the rc8t body is wider than the Xray and the 6t body will fit better I have tried both and the 6t bodies are alot better fit
Jammin57 is offline   Reply With Quote
Old 08-18-2010, 01:16 PM   #9
morgoth's Avatar
Which tires are those? Do you run these on astroturf/gras?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 08-18-2010, 05:08 PM   #10
blade954's Avatar
Hi they are Panther Meat grinders stretched and glued up on AKA rims and foam. They take some time to do but once done they turn your Truggy into a weapon on the Astro or Grass.
Old 08-18-2010, 06:00 PM   #11
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
I have the MBX6-T Punisher on mine and it fits great. Just don't cut the body on the lines or else it will be short in some places and long in others. Just leave everything big when you're cutting it out and trim it to fit as you go.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 08-19-2010, 07:53 AM   #12
thanks gents,. i didnt realise jake was running the panther grinders as appose ot the xtm grinders,. have u tried the xtm grinders..??
dropping the mounts lower on the rear tower wouldnt make that much difference with the mounting would it??? maybe better areo's...
Old 08-19-2010, 09:39 AM   #13
liquidkool's Avatar
XT8 09spec - Werks B5 | XT8 - Picco JL Team Turbo | XT8-V-spec VZB | XB8 - V-spec
XB808 - RB Killer9 l XB808 - RB Killer10
Xray, JR, Byrons, Proline, Futuba, Amain
[THINKFORYOURSELF]
liquidkool is offline   Reply With Quote
Old 08-20-2010, 07:13 AM   #14
hey liquid,. looks good,. looks like u have dropped the rear posts too,.. is it ok just to drill in the carbon fibre rear stand?
Old 08-20-2010, 07:52 AM   #15
pickle311's Avatar
Trader Rating: 31 (100%+)
Yes, I drilled mine with 0 issues. Use a sharp bit so it cuts well and doesn't cause it to crack or anything like that.
pickle311 is offline   Reply With Quote
