Old 08-16-2010, 03:22 AM   #1
Default Nitro engine rev's high
HI all
im new to all Nitro RC i have tuned the engine to factory settings was running well i then tuned alittle more which twicked it up nicley did about 6 runs going good , started it today it idled at 1st after i give it a rev it stayed high and reved more almost to peak so i shut it off,i checked servo return all good. looked in carbi and even with no throttle open it still reves high as in almost over reving i hav no idea whats causing this any advice would be great cheers Rusty1
NOTE it is a Axial 28 engine
rusty1 is offline   Reply With Quote
Old 08-16-2010, 03:31 AM   #2
Sounds like the LSN is to high. But really, you should read the tuning tread and try to get around some one that knows what they are doing. Take it to any track and be cool and someone will help.
The Working Man is offline   Reply With Quote
Old 08-16-2010, 03:37 AM   #3
can the LSN go out of adjustment by itself ?
Old 08-16-2010, 04:10 AM   #4
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
weather my friend as in ambient temps can make the tune change
also is the motor new maybe the plug is bad
more then likely the lsn is lean but as stated above try reading the tuning bible it has some really useful tips that may help u and u will learn a lot for them
P.S
wen at idle does it sound more like a machine gun tin tin sound then its lean
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 08-16-2010, 04:56 AM   #5
P.S
it sounds normal at idle only when i rev it ,it then revs down only slightly then revs up hi if i rev again it gets higher but sounds like its about to peak ,if i brake as soon as i release brake its straight up high as in like full throtle
MMM ???
Old 08-16-2010, 05:12 AM   #6
Trader Rating: 93 (100%+)
Default Carb
Richen up the main needle.
latemodel13 is offline   Reply With Quote
Old 08-16-2010, 10:26 AM   #7
kman16jr's Avatar
Trader Rating: 53 (100%+)
richen up the bottom,than try the top if that doesn't do it.
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 08-16-2010, 10:38 AM   #8
tc5 man's Avatar
i dont know man it sounds like, its the glow plug i had the same problem and there was plenty of smoke coming out of the pipe . and when i put a new plug in it was fine ran good.
tc5 man is online now   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
REEDY .21 Nitro Engine Kevin Boyle Offroad Nitro Engine Forum 1359 10-08-2014 01:19 PM
what is the best way to stop a nitro engine? lewis666 Nitro Off-Road 107 06-02-2014 02:37 AM
Team Orion CRF Wasp Rev X-Dyno results Nano Onroad Nitro Engine Zone 1531 11-07-2010 01:43 AM
RC Nitro Engine break in video david628@ckt.ne Nitro Off-Road 21 09-02-2009 06:30 PM
