will this battery fit?
will this batt fit?
http://www.hobbyking.com/hobbyking/s...~50C_Lipo_Pack
Also looking for failsafe
http://www.hobbyking.com/hobbyking/s...=GWS_Fail-Safe
Also looking for a voltage regulator couldn't find one on the same site.
oops sorry ofna jammin x2 truggy and revo 3.3
seems like it will fit the jammin?
the bigger box is 65mm.... i have my rx in the smaller box, Is 1000mah enough? will the lipos last longer.
i just ran about 10-15 practice and three 5 min heats with 2 min warm up and top off for the main.
ok so what are the regulator batteries called. which should i get?? sorry im a beginner
oh if your new do NOT get a lipo. those can burn up some crap and catch on fire. get the one i sent a link of... it will last alot longer than 100mah lipo and you can run it down and never have to worry about it catching fire like ive seen SO many lipos do before. someone will leave the switch on and then puff there goes all your electronics and possibly your truggy.
thought they would be cheaper buy now... Also what fail safe should i get?
now for the NiMH batterys, i dont run a fail safe, they dont really work, i just use the one on my radio, but for a dead battery i use a rubber O-ring from an auto parts store aroung my throttle linkage and carb to pull it back closed if battery dies or comes un hooked.
