Old 08-14-2010, 01:05 AM   #1
Trader Rating: 44 (100%+)
Default Quick Question Fellas
I recently got a Top bf(novarossi) and it had an untuneable carb so I tried to take it out and replace it with a standard nova one(to add venturi's) no luck there either..well I found an old Go tech case and swapped everything over...but now the compression is so tight it can pop the headbutton out. will this work? I mean it's awfully hard to turn over now(it was good before but now it's outrageous) any quick help would be great
thanks,
jayson
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-14-2010, 01:12 AM   #2
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
thanks,
jayson
never heard of swaping the 2 but with most if not all engine new wont just turn over with out heating them up, get a blow dryier or heat gun(preferable heat gun its much faster) and heat the engine to about 170ish and then it will be way easier for it to crank over.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-14-2010, 07:19 AM   #3
it's not new though lol...it's got like 2 gallons on it..compression was not like that in the old case but when in the go case it's so much it actually pushes the sleeve back down...I think it won't work and i have taken it apart
T5M 7.5
22 3.0 7.5
Old 08-14-2010, 10:44 AM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
did you lose any of the head shims when you did the swap?
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-14-2010, 11:26 AM   #5
I dont think GO and Nova have the same case specs to swap, The only engines ove heard os swapping between each other are 0.s v-spec to ninja, ninja to speed and v-spec to speed and a sirio evo and werks b5. I dont think this will work if GO is italian it might.
Old 08-14-2010, 02:51 PM   #6
Rcrenew's Avatar
+1 I dont think those cases are interchangeable, and if your engine feels different like that with more compression it means, something is off. The sleeve most likey sits lower in the crankcase, raising compression ratio and letting hte piston go past its normal TDC. hope this helps.
Lance,
Rcrenew.com
RcRenew.com engines, modding and rebuilding
http://www.rcrenew.com/
Triton RC- Ultra high performance racing engines
http://www.tritonrc.com/
Rcrenew is offline   Reply With Quote
Old 08-14-2010, 03:07 PM   #7
wingracer's Avatar
Trader Rating: 23 (100%+)
That's what it sounds like to me too. Sleeve is sitting lower so piston is coming up higher.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 09:03 AM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
Courtney Marine Corps Base Off-Road Track Okinawa Japan YDBD Track Locator Forum 922 03-20-2010 02:53 AM
