Old 08-13-2010, 03:46 AM   #1
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Default RC Setup Guild video by Squirrelod
These may already be posted up but I found them to be very helpful and well done, I wanted to share again as Squirrelod has done an amazing job creating these for us the hobbiest.
Enjoy
Sean
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 08-13-2010, 05:06 AM   #2
nickdawg18's Avatar
Trader Rating: 33 (100%+)
i vote for sticky!!!
nickdawg18 is offline   Reply With Quote
Old 08-13-2010, 05:41 AM   #3
tc5 man's Avatar
the brake video was really helpfull ! i never thought about that way.
Old 08-13-2010, 05:45 AM   #4
jeff_ellis_9's Avatar
Default changing shock oil help
I understand you have to dump your old oil, but do you just put new oil in or do you have to clean out the shock body? Any good informational site or even a video for changing shock oils?
I did have a very informative web site a How To on changing the oil, but I had to clean sweep my PC and lost the link. Thanks
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 08-13-2010, 05:49 AM   #5
tc5 man's Avatar
i dump out the old shock oil, and clean out the shock body with simple green or something else. you want to make sure, there is no dirt at all in the shock body.
Old 08-13-2010, 10:32 AM   #6
8ight-racer's Avatar
Dump the old oil, fill it with new unless you want to change the o rings. I clean the o rings every other time I refill the shocks just to clean everything up, but for the most part if you get all the old oil out there will be air bubbles at the bottom below the piston. So I leave a little in there.
Palm Desert R/C Raceway - www.palmdesertrcraceway.com
JQ Products, Pro-Line, TKO, Buku, Werks Fuel, Savox, A Main Hobbies, and Uncle Don's Hobbies
8ight-racer is offline   Reply With Quote
Old 08-13-2010, 11:00 AM   #7
jwm2's Avatar
Dump, refill, bleed, move on.
jwm2 is offline   Reply With Quote
Old 08-13-2010, 11:04 AM   #8
tc5 man's Avatar
yea i refill it with new oil even, though i should clean the o-rings or change them when i do it.
Old 08-13-2010, 11:06 AM   #9
tc5 man's Avatar
you can do that but if theres, a little dirt on the o-rings sometimes it can cause a bind or a butch of air bubbles. that you cant get rid of inless you clean off the o-rings
Old 08-13-2010, 11:15 AM   #10
MikeFriery's Avatar
Trader Rating: 19 (100%+)
you really don't want to clean o-rings.. either replace them or leave them with dirt on them.. Motor spray causes them to swell up.. and everything else doesn't do much.
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 08-13-2010, 11:23 AM   #11
tc5 man's Avatar
i dont use motor spray on, the o-rings i already know what happens to them
i use a little bit of simple green or just replace them.
Old 08-13-2010, 11:31 AM   #12
tc5 man's Avatar
now about the ride he was, showing in the video he must have new front springs or something to get the front arms level. on the eight-t because i can never get my arms even, inless i really crank down on the collers than it makes it too high.
Old 08-13-2010, 01:53 PM   #13
Don't go by 'arms level', 'just below level', its too inconsistent. Buy the Losi ride height gauge and do set it that way, since Losi's are sensitive to ride height.
Old 08-13-2010, 02:10 PM   #14
tc5 man's Avatar
i have the losi ride height gauge, the front is about 35 mm when i drop the truggy off a flat table. and the rear is level, with a little bit of preload but without the arms sagging and there level.
i do wonder why losi made the front end that way ?
yea i have tried higher and , lower ride heights on the losi so i know there sensitive to ride height.
belive it or not on the, 1.0 buggy and truggy on a rough track they handle better with the front a bit higher, and the rear lower i know thats weird but it worker for me.
Old 08-13-2010, 04:01 PM   #15
pyromania's Avatar
Trader Rating: 18 (100%+)
I hope you're not measuring the ride height from the kick-up. You have to measure it from behind the kick up where the chassis is flat.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
