Nitro engine rev's high
HI all
im new to all Nitro RC i have tuned the engine to factory settings was running well i then tuned alittle more which twicked it up nicley did about 6 runs going good , started it today it idled at 1st after i give it a rev it stayed high and reved more almost to peak so i shut it off,i checked servo return all good. looked in carbi and even with no throttle open it still reves high as in almost over reving i hav no idea whats causing this any advice would be great cheers Rusty1
NOTE it is a Axial 28 engine
weather my friend as in ambient temps can make the tune change
also is the motor new maybe the plug is bad
more then likely the lsn is lean but as stated above try reading the tuning bible it has some really useful tips that may help u and u will learn a lot for them
P.S
wen at idle does it sound more like a machine gun tin tin sound then its lean
P.S
P.S
P.S
MMM ???
i dont know man it sounds like, its the glow plug i had the same problem and there was plenty of smoke coming out of the pipe . and when i put a new plug in it was fine ran good.
