Old 08-10-2010, 08:54 AM   #1
Default Throttle return spring when using a torque servo on throttle?
I usually use a 9100s at throttle but they SUCK so i put an extra 9100T i had at throttle. Issue is it takes more spring tension to return the servo to neutral should the servo lose power. I usually run rubber bands so should i just put more rubber bands until the throttle will close? Will the extra load kill the servo? Thanks.
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 08-10-2010, 08:58 AM   #2
Set you trim correctly and you should not need extra spring tension. The servo should center it self. the rubber band should not be use to close the carb, its a fail safe in case the servo loses power. with out the rubber band the servo should be able to close all the way.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-10-2010, 09:08 AM   #3
Right if the servo loses power at WOT the rubber bands on the slide of the carb have to have enough tension to pull the carb closed right? I found that i need more rubber bands on the carb for the 9100T than i did with the 9100S so will the extra rubber bands kill the life of the servo because it has to pull against those.
I understand the spring should be set properly to close the carb with servo under power and no rubber bands. I'm talking only under loss of power situation.
Byrons 30%
Spektrum
Old 08-10-2010, 11:14 AM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
As bacchus explained, that is not correct. The return spring/band needs to be able to return the servo arm completely to neutral in the event of power loss.
bacchus, you should use as many bands as needed. The servo should handle it just fine, especially with more torque to begin with. You'll be fine with more bands.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-10-2010, 11:21 AM   #5
Maybe I should have wrote it differently.
Old 08-10-2010, 11:24 AM   #6
Well you're right about that part. The servo/linkage should close the carb when operating properly, but bacchus was asking about return spring in a loss of power situation. In which case they need to be able to pull the servo closed all the way.
-Koby Kubrin-
Old 08-10-2010, 11:26 AM   #7
Hey jammin what kind of luck are you having with the 7940? Is it lasting on the losi?
Byrons 30%
Spektrum
Old 08-10-2010, 11:33 AM   #8
I'm in love with this servo on throttle. It is absolutely awesome! I've been running it since early November and it hasn't given me one little issue. Both the 40 and 50 have been issue free for me and they're very impressive on direct lipo. I wouldn't trust the 40 on steering though. That seems to be where guys are burning them up.
-Koby Kubrin-
Old 08-10-2010, 11:47 AM   #9
CHOAS's Avatar
My JR z9100hvs burned up on my throttle on my Losi 8T.Got like two months out of it. I replaced it with a Hitec 7940 thv. Do other people have problems with the JR 9100's. I knock the case out on my 9100t in my Revo steering.I blew a few 9100s over the past 3 years on Revo throttle.I am thinking of going Hitec 7940 hvt ,7950 hvs if JR does not want to cover these under Warranty.What do you guys think ?
CHOAS is offline   Reply With Quote
Old 08-10-2010, 11:53 AM   #10
Who8mySandwich's Avatar
The idea of the bands on the carb, is so if the servo horn comes off the servo the carb will still close.
Neil Sandoo
TLR 22 2.0
Serpent Spyder SRX 2
Who8mySandwich is offline   Reply With Quote
Old 08-10-2010, 12:53 PM   #11
Well yes, and if you lose power they will pull the servo/carb closed. They need to be able to do both. In other words, like I've been saying, the bands need to be able to pull the carb closed with the servo connected.
-Koby Kubrin-
Old 08-10-2010, 02:08 PM   #12
Yeah i'm unimpressed with the 9100s regular or high voltage. I literally put a BRAND NEW 9100s at throttle and the second time i pulled full throttle it twitched from full to neutral back to full. It is ridiculous. I set my endpoints correctly everytime as well! I have heard people say for the losi to get 2 7955's and be done with servos. Well i'm assuming the torque servos last longer at throttle and i have 2 9100T's so we'll see. I'm gonna miss the extra speed on throttle tho.
Byrons 30%
Spektrum
Old 08-10-2010, 02:43 PM   #13
The new Hitec 7945 will probably be the bomb for throttle or steering in a buggy. Something like 320 oz/in torque and .10 sec. speed. You can have torque and still have your speed.
-Koby Kubrin-
Old 08-10-2010, 02:52 PM   #14
Nice i'll take a look at that one next season maybe...hopefully the T will last awhile.
Byrons 30%
Spektrum
Old 08-10-2010, 03:07 PM   #15
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
I am running the Sanwa HVS-ZV servos on both the steering and throttle on my MBX-6 with great results, and with speed on .12 at 7.4 volts and torque of 333 in/oz thety are just what was needed to do the job. I am running the M11X also so it was a nice fit having Sanwa allround.
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
Carb return Spring. hdcruzer Nitro Off-Road 19 10-07-2009 02:54 AM
What throttle servo ? joeling Nitro Off-Road 34 07-07-2007 12:09 AM
SON OF A B***H!!!!!!!!!!!!!!!!!! espo16 Nitro On-Road 31 07-02-2005 10:20 PM
Throttle/brake servo broke... again!!! (3rd replacement!) sonep Malaysian R/C Racers 25 10-01-2003 07:27 PM
