Old 08-09-2010, 03:53 AM   #1
lewis666's Avatar
Send a message via MSN to lewis666
Default carb to close to centre diff?
hi there,
here are a few pics of my carburettor and my centre diff. sorry for bad pics.
top view
is the carb to close to the centre diff top plate? should i file the centre diff top plate down abit so there is a bit of clearance?
because i know that losi 8ight do have alot of flex and i have now fitted the BCE chassis and i don't want the carb and diff top plate to hit and damage the carb, should i be worried?
many thanks in advance
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 08-09-2010, 04:23 AM   #2
Ananda Robinson's Avatar
Originally Posted by lewis666 View Post
hi there,
top view
lewis
I had this exact issue with my 8T 2.0 same exact engine setup as my buggy, so im not sure why there is a clearance issue. I just rotated the carb a little until the slide cleared the top of the diff mount. People have posted that the two piece diff mount allows better clearance but i have not gotten around to installing it yet. I can post a pic if you're interested.
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Ananda Robinson is offline   Reply With Quote
Old 08-09-2010, 04:30 AM   #3
lewis666's Avatar
thanks for the comment
i was not looking to buy the split diff mount i wanted to clear it some more just to be on the safe side.
the carb does not hit the centre diff top plate but i wanted to clear it so it does not hit because of the flex of the chassis.
but i have rotated the carb around quite alot but i think i might have to file abit off the diff top plate and see it i can get a bit more clearance.
many thanks
lewis
Old 08-09-2010, 04:37 AM   #4
offroad racer's Avatar
I had this same problem with my buggy a couple weeks ago. All you have to do is loosen the screw that is holding in the carb, and then turn the carb clockwise (assuming the front of the buggy is closest to you) a little.
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 08-09-2010, 04:40 AM   #5
lewis666's Avatar
cheers i will try and turn it abit more and see it that helps
many thanks
lewis
Old 08-09-2010, 05:34 AM   #6
neobart's Avatar
I've had my carb like that in all my 8ight's no problem, looks fine to me.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 08-09-2010, 05:36 AM   #7
siv06's Avatar
Had this on my old losi buggy - I got the dremel on the diff top mount ! Sounds drastic but a few mm removed cures the problem and you can keep the carb much straighter
Neil
Xray Xb8 /D8T.
Bullitt 216
Spektrum/hitec
Pirahna
siv06 is offline   Reply With Quote
Old 08-09-2010, 05:39 AM   #8
lewis666's Avatar
i just don't want them to hit and damage the carb.
thanks anyway
lewis
Old 08-09-2010, 05:40 AM   #9
lewis666's Avatar
Neil
i am going to file a bit off the top mount as you said. just needs some more clearance
many thanks
lewis
Old 08-09-2010, 05:45 AM   #10
Suspended
Trader Rating: 202 (96%+)
+1, looks good to me too
inferno13 is offline   Reply With Quote
Old 08-09-2010, 06:08 AM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
The split center mount helps but the carb is still not completely happy unless you rotate it a little.
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1633 Today 11:17 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Serpent S811 Cobra Buggy Discussion Thread jfc_tech Malaysian R/C Racers 261 12-21-2010 06:37 PM
