Old 08-08-2010, 08:54 PM   #1
rotarynut's Avatar
Trader Rating: 30 (100%+)
Default Cen Matrix R2 center spur gear
Does anybody know if a center diff spur gear from a Kyosho would fit my Matrix? the one it comes with is a clutch bell eating SOB!!! the teeth on it are shapped like this \_/ ,I'd like to find a gear with a wide tooth pattern and spread the load over a wider area, thanks for any info.
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 08-08-2010, 08:59 PM   #2
TRArena's Avatar
the mp777 46T lightened spur gear will work - make sure you use the R2 oring AND a diff gasket.
Mike.
TRArena is offline   Reply With Quote
Old 08-08-2010, 09:07 PM   #3
rotarynut's Avatar
thanks TRArerna, man the stock gear sure eats'em up, I checked the Cen site but did not find the answer, I'll def get a MP777 gear and a gasket. I'm not sure that the MXS24 would be any better. what do you think?
Robert S.
Old 08-09-2010, 06:28 AM   #4
Ruune's Avatar
Send a message via ICQ to Ruune Send a message via AIM to Ruune Send a message via Yahoo to Ruune
the entire center diff will fit too.
Ruune is offline   Reply With Quote
Old 08-09-2010, 07:29 AM   #5
rotarynut's Avatar
Thumbs up
thanks for the info guys!!
Robert S.
Old 08-09-2010, 08:45 AM   #6
Ruune's Avatar
actually... you might want to try the kyosho's big bore shocks too. I know the ST-RR ones work quite well on the TR. Also, most people that have done the truggy to the buggy-style chassis brace conversion use the ST-RR hardened diff gears for front and rear. you'll find that a LOT of parts are interchangeable. The hotbodies gears should work too.
Old 08-09-2010, 05:17 PM   #7
rotarynut's Avatar
Thumbs up
I have two sets of Jammin 16mm big bores, they seem to work good. So you're saying that the ST-RR gears (ft, center ,rear) will fit on the R2 cases?
as well as the hotbodies gears (D8?) thats good to know, it opens a window should parts availability become an issue. Any more parts that can be swapped... I'm all ears!!
Robert S.
