Old 08-08-2010, 06:56 PM   #1
xBRxSAIGON's Avatar
Default Another XXXNT Engine Ques.
I'm sure somewhere on this sight is the answer but I cant find It, WILL a Picco .12 JLR or similar engine with that style of crank mount up with the stock flywheel that was on a mach .15 all threaded crank properly i know the NT is getting older and its hard to find those older style engines with the all threaed cranks... Does anyone have a stright answer on this,,, thanks
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Old 08-08-2010, 07:10 PM   #2
tc5 man's Avatar
get the dynamite, red head .12 engine it has a treaded crank shaft it is a old engine but it has enough power for a staduim truck.
Old 08-08-2010, 07:20 PM   #3
xBRxSAIGON's Avatar
LOL thats the engine I have in it right now... It's got some power but i'm looking for some more ripp.
Old 08-08-2010, 07:26 PM   #4
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
sirio .12 best engine ever very smooth lots of power. but might be hard to find
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 08-08-2010, 08:26 PM   #5
tc5 man's Avatar
oh there might be, a few .12 engines with a treaded shaft but i woulnt remmend a engine with, a slide carb for a 2wd truck trust me i know lol.
Old 08-08-2010, 08:55 PM   #6
xBRxSAIGON's Avatar
Cool, Now we're gettin' somewhere, why not and what about those SG cranks in an NT???
Old 08-08-2010, 09:09 PM   #7
tc5 man's Avatar
well you dont want, a slide carb on a 2wd truck because the throttle reponsed is too sensitive on those trucks.
i used to run a gt2, with a dynamite .12 platnuim engine with a sg pilot shaft.
im not sure if you can use a sg shaft on a nt .
Old 08-08-2010, 09:12 PM   #8
I've raced the xxxnt for years and to my knowlege you can not use a SG crank engine with the xxxnt.
topcat-lll is offline   Reply With Quote
Old 08-08-2010, 09:19 PM   #9
xBRxSAIGON's Avatar
Thanks fellas, I know you can switch the linkage around for a slide carb setup but i just cant seem to get a definate answer on the sg crank thing, i'm not opposed to the all-threaded/rotory engines they just have alot of SG/slide Picco .12's on ebay for cheap all of the time...
Old 08-09-2010, 08:17 AM   #10
Trader Rating: 45 (100%+)
I put a TZ .12 in a xxxnt ,I had to make my own motor mount but it works just find , I have a slider clutch ,and a slide carb ,,,
rc racer 103 is offline   Reply With Quote
Old 08-09-2010, 01:19 PM   #11
xBRxSAIGON's Avatar
So were you able to use a standard 2 shoe flywheel? and whats a slider clutch?
Old 08-09-2010, 04:41 PM   #12
yes you can use a 2 shoe clutch , for a slider clutch look at traxxs
