Old 08-07-2010, 03:46 PM   #1
Trader Rating: 20 (100%+)
Default Droop setting
Please help me understand it. I have a losi 8T 1.0 and 8B 1.0. I cant figure out how important it is. Tried to play around at the track with different setting. Totally clueless. Many thanks.
P.S My losi are running very loose on "on-power" steering too..
xxx123 is offline   Reply With Quote
Old 08-07-2010, 05:19 PM   #2
fattyalan's Avatar
Default YOUR BIBLE!!!
here you go mate
download it and it will be your bible through Off road rc
http://www.teamxray.com/teamxray/sho...p?file_id=4461
it has other stuff inside as well have fun
Hot Bodies D8
O.S V-spec EB mods
Spektrum DX3R
Nitro-X Fuel
fattyalan is offline   Reply With Quote
Old 08-07-2010, 07:13 PM   #3
tc5 man's Avatar
i have a eight-t 1.0 too, if its loose on power get the 3/3 rear toe in plate that will help a lot with the rear being more stable.
but it does take some steering away.
and also use the thinnest rear sway bar for more grip.
once you get a good setup on the eight - t its not bad.
Old 08-07-2010, 07:31 PM   #4
rotarynut's Avatar
Trader Rating: 30 (100%+)
Thumbs up Off road bible
It really splains things, it answered a bunch of stuff that wasn't clear to me. good link
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 08-07-2010, 08:02 PM   #5
thinnest sway bar for front or back?? tx
Old 08-07-2010, 08:10 PM   #6
tc5 man's Avatar
back i havnt tried a thinner front sway bar yet.
what is the track suface like where you race on ?
also make the rear ride height, low as you can where the rear arms are level .
and for the front make it about 2mm higher than the rear.
and the gray rear springs, work the best and the front black springs also.
Old 08-07-2010, 08:25 PM   #7
Looks like the droop screws are used to fine tune the ride height...
Old 08-07-2010, 08:28 PM   #8
My track is havng a lot of ripples turns and many quad midgit jumps...
Old 08-07-2010, 08:32 PM   #9
tc5 man's Avatar
than try the things im using than , make the rear a little higher than since you have quad midgit jumps.
i race on a rough rutty track and its dusty most of the time.
are you using the short rack for the steering ?
Old 08-08-2010, 01:42 AM   #10
The dropscrews are used for adjusting arm-travel. It's with the shocks you adjust rideheight (using spacers on the shocks, on a Kyosho).
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
BNT Droop Screws xxxntmaster Nitro Off-Road 80 03-14-2013 11:49 AM
Correct Droop Setting...Help! Terry M Electric On-Road 15 04-25-2008 11:20 PM
setting droop correctly? sbmon Nitro On-Road 128 12-30-2003 05:24 AM
