Diff Problem
Diff Problem
Ok I was fixing my front differential case of my Losi 8oght 2.0. I took out the four screws holding the case together. I took out the large gear from it. After i got to the smaller gear that turns the larger one i couldnt get the setscrew holding the pinion coupler onto the gear. I know that it may have Losi-Lok (Lock Tight) on it so how would i go by getting it off
Heat gun or hair dryer to try heating up the losi-lok. If it is losi-lok it's supposed to be easily removed with tools. Are you talking about the set screw in the driver adapter under the dust boot??
by the way MotoGod, love the avatar.
I am taking out the setscrew inside the front diff case on the thing that turns the gear
Wont let me post a pic, but go to google or something and type in rc pinion coupler and look at images it will be the first pic and that is the screw that i need to get out and that is the part that it is in
impaktrc.com/images/LOSA3514-450.jpg
oo yea that hold ur pinion to ur cvd, once u remove the set screw the pinion gear will slide right out of the diff case, if u strip it which isnt good u would have to drill it out cus dremel wount work unless u get luck but if its not stripped and worried about stripping heat it up like moto and jeff said and it will loosen up way easier.
ruined 5 wrenches without stripping the set screwwow last resort would be drill it out but you will need a whole new piece but you shouldnt need to remove that unless case is cracked, bearing is bad, or pinion gear is shreaded and if the pinion is shreaded im sure ur outter diff gear is hurt aswell.
k il let you know if i ever get it out
yeah if theres nothin hurt i would leave it alone, lost diff bearing dont really go bad fo a long time and pinions should last forever only issue is cvd wear ond once thats wore out you will need a whole cvd anyways so the drill wont hurt. The only thing u drill into is the cvd so ur pinion will not be affected.
actually the front diff is screwed up cause these 2 prongs on the top are broke off cause i ran it into the tire of a car (dont even ask) so i dont just wanna waste a perfectly good parts in there
