Old 08-06-2010, 05:54 PM   #16
Trader Rating: 26 (100%+)
http://www.youtube.com/watch?v=WhpwsjYoxM0
bphil49 is offline   Reply With Quote
Old 08-06-2010, 06:59 PM   #17
A little heat is necessary when using the tool.
The tool brings a lot of ease when you are at the track.
By using the oven is the best as zero material from the casing will be remove. These are micro engine and have minimum tolerances if we got it all wrong.
king offroad is offline   Reply With Quote
Old 08-06-2010, 07:17 PM   #18
rotarynut's Avatar
Trader Rating: 30 (100%+)
Questions?? save a bearing
I'm trying to save a ft bearing that I put in a OS21RG, the rod gave up the gost 2 tanks after the install, it's a Boca ceramic with the double seal, I can use it on another engine that I have. I don't have a bearing tool, do you think that I could heat up the block enough to push the bearing out from the back without the heat damaging the seal? thanks for sharing your wisdom.
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
