Old 08-06-2010, 11:28 AM   #16
tkge's Avatar
Trader Rating: 97 (100%+)
If your motor runs high for a few seconds then drops, that usually means its a little rich on the bottom. Lean it a little at a time and drive it around then check it again. Should run constant idle for 10-20 seconds without a change. Now leaning out the low speed needle will make it idle higher, but when it stays constant for that 10-20 seconds, you know you have the bottom set right, then adjust the idle screw to lower the idle speed. Test again to make sure top speed is still set right because leaning out the bottom end will sometimes make the top too lean, may have to adjust it an hour or so to the rich side.
Hope this helps..
Tim
Tim Dunn
Tekno | Pro-Line | Maclan | DialedRCHobbies
tkge is offline   Reply With Quote
Tamiya TB-03 gtypecanare Electric On-Road 2317 07-25-2017 08:04 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 01:01 PM
SJCCR Slowbirds Nationals, Horsham, January 31st Ray Murray Racing Forum 466 02-24-2010 09:05 AM
Why are buggies built this way? DOMIT Nitro Off-Road 40 11-12-2007 05:29 PM
