Old 08-04-2010, 09:32 PM   #1
Trader Rating: 22 (100%+)
Default What % of fuel for .21 engine?
I'm new to .21 engine. Which % of fuel should I buy? 20%,25%, or 30%?
I'm going to use Novarossi Plus 21-5K on Losi 8ight-B 2.0.
Let me know, thanks.
Losi 8ight-T 2.0--RB WS7
Slash 4X4--Castle Sidewinder SCT
rcs950racer is offline   Reply With Quote
Old 08-04-2010, 09:40 PM   #2
tc5 man's Avatar
i would go with 20 % but, get a race bleaded formula 20 % seems to make my engine run cooler and it gives you a wider tuneing window. i have ran 25% before and i cant tell that much of a diffrence.
ge ebmods 20 % race formula if you can.
Old 08-04-2010, 09:46 PM   #3
Will Byron or Sidewinder race one nice too?
Old 08-04-2010, 09:47 PM   #4
tc5 man's Avatar
i would go with, byrons fuel i have tried that fuel before and liked it .
Old 08-04-2010, 10:10 PM   #5
jsp619666's Avatar
with that motor you need to run either 25% or 30% running any less is going to cause extra stress on the motor, imo i would ask the guy from huston engine service on here what to run, he has his own thread.
20% nitro is not enough to make power with your mill or any mid-high end race mill, they simply are not designed to run that low of percentage of fuel, your going to over stress the rod and your fuel millage will be terrible.
Josh Peters
jsp619666 is offline   Reply With Quote
Old 08-04-2010, 10:24 PM   #6
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
30% byrons race gen 2 have always worked great for me never had an issue and isnt as pricey as eb mods...eb mods is a bit more than what a normall club racer would spend on a gollonplus alot of hobby stores carry them theres nothing like goin to a race and expecting to buy fuel because ur low and they dont carry eb mods or torco etc etc.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-04-2010, 10:26 PM   #7
tc5 man's Avatar
really i never heard of that one ?
ive ran a nova .21 bf and, now a rb s5 engine thats shimmed for 25% but ive been running 20 % it seems to make enough power.
Old 08-04-2010, 10:38 PM   #8
jmaxey51's Avatar
sluggish bottom tho. and those are sport engines nothing like the engine the guy is running. 30% is needed. i used to not tell the difference but now that ive gotten alot faster and tested the difference, there is a HUGE difference down low but not much up top.... if its shimed for 25 or 30% run that or you will have problems tuning the bottom whether you realize it or not. run byrons 30-9 in that BF and that thing will come alive
jmaxey51 is offline   Reply With Quote
Old 08-04-2010, 10:42 PM   #9
tc5 man's Avatar
well ive already got, a gallon of 20% so im not driving a half hour to return it and ebmods doesnt make 25 % anyways.
the s5 might be a, sport engine but it seems to be fast enough for club racing.
i know i can get more bottom end, i just need to lean out the low end more once my first gallon is done.
Old 08-04-2010, 10:48 PM   #10
jmaxey51's Avatar
i know i can get more bottom end, i just need to lean out the low end once my first gallon is done.
run 30%, its fine, you will still get long engine life. also leaning out the bottom still wont get the bottom the 30% will get, i went with 20% this weekend to get rid of it and i had the bottom so lean that if i leaned it one hour i would get a lean idle, and it still had no snap hardly. i thought my clutch was bad. also running 30% made my engine run about 15 degrees hotter too.
Old 08-04-2010, 10:54 PM   #11
tc5 man's Avatar
il try ethier 25 % or 30 % once, i finish my new second gallon i cant waste a whole new gallon.
il just lean out, the low end little by little not any big turns .
Old 08-04-2010, 10:57 PM   #12
jmaxey51's Avatar
yeah thats why i burned up the rest of my 20%, i didnt want it to just sit there, i used to run 20% in my JPX bc it would snap a rod if you ran 30% bc of the shimming and mad pinch, but it has 9 gallons on it so im runnng 30 on all my engine now, JPX is back up engine.
Old 08-04-2010, 11:02 PM   #13
tc5 man's Avatar
i have brand new, alum clutch shoes so i should get enough punch that i want.
and leaning out the low end little by little more.
also dont run hard, alum clutch shoes they slip too dam much lol.
and heat up.
Old 08-04-2010, 11:05 PM   #14
Lille-bror's Avatar
That's not true. Nitro is like acid in an engine. Less is better. In a buggy, you'll not see a difference in performance with +/- 10% nitro for a avarage driver, unless you drive on bluegroove tracks.
Less nitro = remove a 0,1 or 0,2 mm shim and perhaps use a hotter glowplug.
Run less nitro and use the saved money on good tires. Then you get your laptimes down.
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 08-04-2010, 11:11 PM   #15
tc5 man's Avatar
well im running a truggy, with a odonnell #100 plug which is a meduim plug.
What do you guys think of this Werk's .21 Engine? Garet Jax Nitro Off-Road 82 07-20-2016 04:40 AM
Most fuel economical .21 RUF-VK Nitro Off-Road 28 02-12-2010 02:31 PM
racing and fuel milege aside. What is the most powerfull engine you can put in a dreaux Nitro Off-Road 51 07-11-2009 04:46 PM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
NTC3 - lots of extras for sale! Greg Amendola R/C Items: For Sale/Trade 24 07-07-2004 05:37 PM
