Old 08-05-2010, 11:37 AM   #16
FLHX1550's Avatar
I too have experienced allot of wheel cracking issues with the AKA wheels. It is a doubled edge problem, as they crack easy, but usually from hitting the susp arms when you have the wheels turned and hit something (or someone hits you)
I think the PL wheels are tougher, but I have had good luck with JConcept wheels. Losi wheels are nice also
FLHX1550 is offline   Reply With Quote
Old 08-05-2010, 11:47 AM   #17
t8rtot's Avatar
Trader Rating: 14 (94%+)
Anyone have info on the Ofna Inch-up wheels? You get 6 in a pack and they cost the same as the others w/4... they're supposed to light aswell..
Sfida
t8rtot is offline   Reply With Quote
Old 08-05-2010, 06:31 PM   #18
mblgjr's Avatar
Trader Rating: 86 (100%+)
Maybe I missed this in the chart...
But when I weighed the AKA buggy and PL V2 buggy wheels; the AKA's are 5grams lighter; per wheel.
I've had trouble with the PL's distorting in the past and decided to get away from them. I've been running AKA's with zero problems, no cracks or memory distortion.
I've also run the newest Losi wheels. They seem to be good as well, though maybe a touch narrower than most on the market.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 08-05-2010, 07:17 PM   #19
KWT-NITRO's Avatar
Originally Posted by Semple View Post
Use the AKA wheels, Proline tires and Proline Evo foams.
thanks for the answers guys, just to make sure, Evos are the black striped ones (lighter than the blue ones) am i right??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 08-05-2010, 07:24 PM   #20
You've got it.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 08-05-2010, 08:17 PM   #21
Integra's Avatar
cheers
Ali
Very Nice foams i might add....you shall enjoy.
Old 08-05-2010, 08:26 PM   #22
jk1152's Avatar
I've use
AKA -> Scuff easy, good for one set, don't like the knife edge on the inside bead. Good hex mold.
Proline V2 -> The best out of the 3. Can be reused. Shiney outside that does not go dull like AKA. Good Hex mold.
OFNA Inch Ups -> Ok, shiney outside like proline, hubs hex is not as good as proline's sometimes I'm tightening them up and they rotate on the hex. Not quite as wide as proline / aka but good enough, wider then standard wheels.
My favorite are proline's V2's. I run AKA rubber and foams.
jk1152 is offline   Reply With Quote
Old 02-16-2011, 04:26 AM   #23
Jstall7543's Avatar
"Proline V2 wheels are Larger in diameter and width than previous wheels to give your car more traction and stability. The V2ís are 1.3mm wider and 3mm taller than the traditional size 1:8 wheels, which transfers into a stiffer side wall for less side wall flex enhancing stability and connectivity with your 1:8 buggy. This is achieved by using the same size 1:8 tires that you use now."
The v3 wheels rub on the front on RC8B, the v2's are wider but don't rub! I like both versions.
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 02-16-2011, 06:59 AM   #24
Integra's Avatar
PL V2's aren't any bigger the AKA or any other brand at the current time.
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Pro Line VS AKA tire size pickle311 Nitro Off-Road 41 07-29-2010 08:58 PM
