Old 08-04-2010, 07:45 AM   #1
gabor szilagyi's Avatar
Default How to drill hole on the spur gear?
I been trying to drill holes on the mugen spur gear,to lighten it up.Notthing sings to be work.That gear is just soo hard,and kill the bit almost right a way. I have tryed diff kind of bits what I could find in hardware and tool stores .I am using drill press with low rpm plus using cooling cut fluid to.I wondering if anybody knows what is the right way or the right bit .thanks!
gabor szilagyi is offline   Reply With Quote
Old 08-04-2010, 08:12 AM   #2
liquidkool's Avatar
you need a bit harder then the metal you're drilling..the ring gear is most likely hardened so you'll need tool steel or spring steel....good luck
liquidkool is offline   Reply With Quote
Old 08-04-2010, 09:13 AM   #3
pickle311's Avatar
Trader Rating: 31 (100%+)
Take it to a machine shop and let the pros do it for you. The last thing you want is something that turns that many RPMs out of balance.
pickle311 is offline   Reply With Quote
Old 08-04-2010, 09:37 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
If you have a drillpress then just bolt the slamp on the table, find a piece of round material fitting the hole of the gear and mount it in the clamp outside the center of the drillbit.
With the gear on it you kan drill the hole and turn the gear to the next position.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-04-2010, 09:38 AM   #5
You right about the ballance ,of corse if I do I do it the right way keep the balance ect...I can do it I just can't find a right bit ...never seen hard material like this spur gear...no wonder why is it 40 $..lol..Thanks!
Old 08-04-2010, 09:40 AM   #6
Thanks Roelof!I'll give a shot!
Old 08-04-2010, 11:14 AM   #7
UK.hardcore's Avatar
These parts are tempered and will be near impossible to drill into.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 08-04-2010, 01:18 PM   #8
I know Savoya does (or somebody does for him) .I just want to know how....
Old 08-04-2010, 02:39 PM   #9
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Gabe- give it to Mike Troxler at the indoor track in G-Boro. If anybody in your area can do it he can. He could either do it or get you a bit. If it's that hard, the bit will probably cost more than the gear, lol.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 08-04-2010, 02:56 PM   #10
Trader Rating: 96 (100%+)
You can use either a carbide drill or , if you have access to a Bridgeport, a carbide end mill.
Or, send it to me.
K.Copeland is offline   Reply With Quote
Old 08-04-2010, 03:12 PM   #11
Stanton's Avatar
You need a solid carbide bit. They are pretty spendy though. The ones I get are from McMaster Carr and cost about $30.00.
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 08-04-2010, 03:30 PM   #12
Ok thank you guys!
Old 08-04-2010, 06:21 PM   #13
What size do you need? I may have one lying around.
PM me.
Old 08-04-2010, 06:46 PM   #14
Cobalt are also very hard and do great at cutting hard metals.
MattFL is offline   Reply With Quote
Old 08-04-2010, 06:57 PM   #15
[fail]'s Avatar
It might help to drill a small pilot hole first then come back with a bigger bit.
AtoZrc.net
JConcepts
[fail] is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Thunder Power Rc 40C 5000 Lipo ThunderPowerRC Electric On-Road 439 02-25-2010 03:35 PM
What Does everyone think of the TB-O2?? catchm3srt Electric On-Road 29 04-05-2007 10:24 PM
