Old 08-04-2010, 07:25 PM   #16
v6shooter's Avatar
Originally Posted by MattFL View Post
Cobalt are also very hard and do great at cutting hard metals.
i just did it on a cobalt drill bit u can get one on a snap-on or mac but it will cost u as much as buying a lighten gear.
My is a set for and the set is 400.00.Just for my line of work.
v6shooter is offline   Reply With Quote
Old 08-04-2010, 08:20 PM   #17
gabor szilagyi's Avatar
I have find one on Mcmaster for 14$ 4mm(solid carbide bit) should do the job..
gabor szilagyi is offline   Reply With Quote
Old 08-05-2010, 09:37 AM   #18
hakmazter's Avatar
I tried it for fun and wasted 3 different drill bits from Home Depot. One of the bits did go through, but then it was dead. At $3 each hole (1 bit per hole), it is better to just buy a lightened one if they are available.
I mass produced the first electric 1/8 scale buggy and truggy.
www.HopeWDM.org
I have thousands of dollars of caster racing inventory available.
Semi-Retired from this industry at this time.
hakmazter is offline   Reply With Quote
Old 08-05-2010, 10:05 AM   #19
Slider30250's Avatar
Check with Tonys Screws, he has the light weight Mugen spur gears for 35$ and some change on his website.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 08-05-2010, 08:27 PM   #20
Originally Posted by gabor szilagyi View Post
I been trying to drill holes on the mugen spur gear,to lighten it up.Notthing sings to be work.That gear is just soo hard,and kill the bit almost right a way. I have tryed diff kind of bits what I could find in hardware and tool stores .I am using drill press with low rpm plus using cooling cut fluid to.I wondering if anybody knows what is the right way or the right bit .thanks!
After reading this thread imo the right way would be to buy the gear you need. Good luck .
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Old 08-05-2010, 08:37 PM   #21
You right the best to buy one.I did not know it's available .R those gears same material as the stock one ?
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Thunder Power Rc 40C 5000 Lipo ThunderPowerRC Electric On-Road 439 02-25-2010 03:35 PM
What Does everyone think of the TB-O2?? catchm3srt Electric On-Road 29 04-05-2007 10:24 PM
