Old 08-03-2010, 10:56 AM   #1
Default Tunning a messed up engine
Hello,
I have a Novarossi N21R and I have changed my fuel from 25% to 30% nitro. The engine didn't start so I messed with my high speed and low speed needle. Now its so messed up I don't know where to start from. Could someone guide me through please if possible?
Thanks.
Jaap is offline   Reply With Quote
Old 08-03-2010, 11:00 AM   #2
neobart's Avatar
Starting point on a Novarossi carb is flush or close to on both LSN and HSN.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 08-03-2010, 11:02 AM   #3
what do you mean by flush?
Old 08-03-2010, 11:02 AM   #4
tc5 man's Avatar
your best bet is too set the needles, to the factory settings and lean the top and bottom end needle about 1 turn, that should make the engine fire.
Old 08-03-2010, 11:08 AM   #5
neobart's Avatar
Flush= top of needle is level with it's surroundings.
Old 08-03-2010, 11:10 AM   #6
how will i know factory settings? is it flush as explained above?
Old 08-03-2010, 11:20 AM   #7
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Factory Novarossi settings=
Flush top and bottom needles.
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 08-03-2010, 11:35 AM   #8
jwm2's Avatar
They are just trying to get you to a starting point. Once the engine has fired up and heated to its normal operating temps then you can tune it and get it running the way you want it to. But you can't tune it without it firing up. You can tune it no matter how the needles are set but you may damage the engine if its too rich or too lean. So a safe place to start is the factory settings which is evidentially flush on both hsn and lsn and go from there.
jwm2 is offline   Reply With Quote
Old 08-03-2010, 12:09 PM   #9
Other than fouling glow plugs, what else are we damaging by running too rich? I'm getting worried, since I've always heard that running slightly rich is playing it safe. Is excess oil bad for engine life?
TPJ International
071crazy is offline   Reply With Quote
Old 08-03-2010, 12:16 PM   #10
I'm still trying to master tunning myself, but another thing to check before you start trying to get it running is your idle gap. If your idle gap is open to far the factory settings for your needles won't help any. Try to get your idle gap set to .5mm or a little over that.
bevofrancis is offline   Reply With Quote
Old 08-03-2010, 12:17 PM   #11
tc5 man's Avatar
replace your carb o-ring if there, is a tear or if it just went bad it wont tune right at all and cause flameouts.
Old 08-03-2010, 12:36 PM   #12
T$
T$'s Avatar
I have a Novarossi N21BF. On mine, flush for the HSN is a good starting point, but if I were to set the LSN flush it would be WAAAAY too rich(definitely would not run).
For a ballpark LSN setting I turn the screw all the way in(while pulling the carb open slightly), then out 3 - 4 turns.
It's possible your engine has a different carb, but I just wanted to put that out there...
T$ is offline   Reply With Quote
Old 08-03-2010, 12:46 PM   #13
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Too rich isn't really playing it safe, although it is safer than too lean. These engines run best when tuned right..not too lean, and not too rich, and that's how they'll perform the best, get better runtime and last the longest.
Running too rich, means it will be running too cool for the cylinder to expand properly causing your piston to slam into the taper of the sleeve, thereby shortening the life of your mill.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 08-03-2010, 01:45 PM   #14
neobart's Avatar
Might be possible, the Nova carb I have is the never type with the idle screw facing the cooling head when installed in a buggy(not Serpent).
EB Mods JS Engine fievel Offroad Nitro Engine Forum 1846 09-28-2011 09:56 PM
