Old 08-02-2010, 08:24 PM   #1
Default 8ight T 2.0 RTR issue
I just bought the eight t 2.0 rtr the other day and I am having a problem. During the break in, the front left dogbone popped out of the outdrive cup. I got it back in ok, but today at the track, it did it again. My camber is almost -2, -1 more than suggested from factory. The left dogbone is right on the edge about to come out all the time, but the right one is in far enough that it's not even close to being a problem. I thought about shimming the cvd on the inside, but there is still not enough play there to matter. What could be causing this? I am at a loss. Here are some pics to show you what I am talking about.
side that keeps popping out
other side
And as an update, I replaced the cups today, but the left side is still close. It is noticeably closer to the edge that the right one. I think it will say in now, but not for long I can't imagine. It's still bad close.
cchriste is offline   Reply With Quote
Old 08-02-2010, 08:33 PM   #2
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Default axel
Check your hinge pin , make sure its not bent. And your droop screws, make sure there in the arms? They do run close to the outside of the drive cups.
Serpent S11T Losi ten scte Houston Tuned Team Toronero 2084 ss, plus 4 team 9901 ss pipe Hitech servos Proline tires SPONSORS T@T MOTOR SPORTS AND SKIDOO racing TEAM TERRIBLES,And finally my wallet.In Memory of my Boy Brian!
teamlosi906 is offline   Reply With Quote
Old 08-02-2010, 08:37 PM   #3
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
check your droop setting.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 08-02-2010, 08:39 PM   #4
I'm sorry....what?
Old 08-02-2010, 08:44 PM   #5
oh ok I found it in the manual. But how is droop adjusted? sounds like the same thing as ride height to me. And why would one side be different than the other? I'm sorry I am so ignorant. Just trying to learn. Thanks for the help.
Old 08-02-2010, 08:48 PM   #6
Do-Over's Avatar
There is a droop screw you tighten or loosen on my associated I assume the Losi is the same....
AE RC8T, Futaba,A-Main by Massive Mods, Hitec,
JConcepts, Fastraxx Hobbies, Team Terribles,
Do-Over is offline   Reply With Quote
Old 08-02-2010, 08:49 PM   #7
Cory Kerber's Avatar
Droop limits the amount the shock can travel. You can adjust it by the grub screw located on the arms near the bulkhead.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 08-02-2010, 08:49 PM   #8
jmaxey51's Avatar
if you race, i would take it to the track and ask someone for help. its hard to tell you over the net. or take it to your local hobby store and they should help/show you.
jmaxey51 is offline   Reply With Quote
Old 08-02-2010, 08:56 PM   #9
yea, I know it's tough. Thanks for trying though. I did screw in the droop screw a little and it evened out the locations of the cvds, but will having droop adjustment done to just one side affect the handling?
Old 08-02-2010, 09:00 PM   #10
Put the car on a stand so the tires are off the ground. Measure the front shock from screw center on the arm to the nut center on the tower. Make the measurement the same on each side by adjusting the droop screws.
*TEAM TERRIBLES*
Old 08-02-2010, 09:05 PM   #11
ok, I think I get it. The droop setting on each side should not matter. Who cares how many turns in the left is compared to the right....as long as the shocks are the same length? I think I got it
Old 08-02-2010, 09:12 PM   #12
The settings won't be the same, but it shouldn't be 3 turns different either. Get the shocks to be about 110mm and you should be good to go. If you still have issue with the driveshafts after that, then check your hinge pins.
*TEAM TERRIBLES*
Old 08-02-2010, 09:24 PM   #13
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Popping driveshafts is a big hint of a bent hinge pin. Set the droop between 107-110mm first to make sure that's not the problem. If they're still popping or close to popping, check out the hinge pin.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-03-2010, 08:14 AM   #14
guntek18's Avatar
Trader Rating: 16 (100%+)
Angry
my buddy has this same problem,
i cant imagine that even if ithe hinge pins were straight that it would be enough. they should'v made/ used longer cvd's in my oppinion (at least 4mm longer) that way this would not be an issue in the event of bent hinge pins during a race. my buddy's is even worse. whats odd is that its the same side!!
guntek18 is offline   Reply With Quote
Old 08-03-2010, 09:49 AM   #15
If the higne pins are ok, its has to be the droop.
if they are longer they would not provide enough room to for the suspension to travel.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
