Old 08-01-2010, 06:41 PM   #1
Dr. Evil's Avatar
Talking Resurrecting a Mugen Ninja GRP/ RB Worlds S7
I have a Mugen Ninja MR21 B01 made by GRP. I need a pistion /sleeve/bearings.
is it true TQ racings motor is exactly Identical. Just trying to confirm.
Also, if they have more than one motor, which one.
I also need bearing size front/rear
Also, I need bearing sizes for a RB concepts Worlds S7 front/rear.
Would like to bring both back to life.
Thanks.
Dr. Evil is offline   Reply With Quote
Old 08-01-2010, 07:24 PM   #2
Dr. Evil's Avatar
Talking Bearings
Hi. If anyone knows the Mugen MR21 bearing sizes, I would appreciate it.
Thanks much.
Old 08-01-2010, 07:56 PM   #3
the bearing size is the same as the v-spec
custom modded .28XZ Powered REVO.....65MPH...so far.
absolutemayhem is offline   Reply With Quote
Old 08-01-2010, 08:04 PM   #4
Infinity's Avatar
Trader Rating: 16 (100%+)
Default Bearing sizes
Hi,
The front bearing is the common 7x19x6mm
The Rear Bearing is 14x25.4x6mm
I'm afraid you'll be hard pressed to find a p/s/conrod set available these days for the Mugen GRP based Ninja MR series engine. You'd be better off trying to source these similar parts from TQ or Reds or even Tecno-power as these engines are exact productions of the GRP based engines.
Infinity is offline   Reply With Quote
Old 08-01-2010, 08:16 PM   #5
Trader Rating: 47 (100%+)
Check your PM's Dr. Evil, "rageworks" will get ya going.
rageworks is offline   Reply With Quote
Old 08-01-2010, 10:21 PM   #6
pyromania's Avatar
Trader Rating: 18 (100%+)
The P/S/R from TQ's 501T will fit the MR Ninja. Have your hobby shop call TQ or email them at info@hobbyworks.com
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 08-25-2010, 03:02 PM   #7
Dr. Evil's Avatar
Default re: front bearing
Hi. The front bearing in my engine seems to just want to fall out. I can put the bearing in with my pinky. I don't see any kind of a crack in he case.
Any suggestions??
Old 08-25-2010, 03:09 PM   #8
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Default p/s
Thanks.
There is a grp new tuned p/s and rod on.here forsale 110.00 shipped. Same thing.
Serpent S11T Losi ten scte Houston Tuned Team Toronero 2084 ss, plus 4 team 9901 ss pipe Hitech servos Proline tires SPONSORS T@T MOTOR SPORTS AND SKIDOO racing TEAM TERRIBLES,And finally my wallet.In Memory of my Boy Brian!
teamlosi906 is offline   Reply With Quote
Old 08-25-2010, 03:31 PM   #9
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Originally Posted by Infinity View Post
Hi,
Incorrect
Tecno Power Engines have different P/S, case, carburetor, head button, cooling head and crankshaft (pretty much the whole engine) compared to the old school GRP engines.
The Tecno Power internals will interchange without any problems, but to clear the air Rody's internals in his designed engine are in fact updated and improved. The TQ engine will most represent the original GRP engines with only a rod and carburetor updates.
Nothing against the TQ or GRP original engines, they are great running engine today as they were years ago, but not the latest Rody design or development.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-25-2010, 04:13 PM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Any suggestions??
You've either got the wrong size bearing or there is something SERIOUSLY wrong with your case.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-25-2010, 08:03 PM   #11
The front bearing probably spun in the case.
Dirtdobber is offline   Reply With Quote
Old 08-26-2010, 07:10 AM   #12
Dr. Evil's Avatar
Talking Front Bearing
Sounds to me if you are correct about the spun bearing, (Hmm) I guess
If I like that kind of engine, I should get the TQ and not do an upgrade.
Does the TQ use the same bearings?? The ninja has ceramic bearings.
I don't think the TQ has them right??
In reference to the RB Concepts WS7, I tried to get this to run right. Found I
had a problem with the buggies brakes (They were too tight) and after fixing
this problem, the engine temps dropped 80 degrees. Also, after this fix and
getting the temps right. The engine was pulling wheelies up until the
connecting rod snapped and threw debris all over the engine.
Oh well, I had a new p/s/con rod, so I am going through a break in with this.
Old 08-26-2010, 05:06 PM   #13
cordarrow's Avatar
wow..............
cordarrow is offline   Reply With Quote
Old 08-26-2010, 05:52 PM   #14
motomatt's Avatar
The TQ engine is exactly the same as the GRP ...........EXCEPT........... the TQ has an improved rod (which will still fit your GRP) and a change to the carb. These were the improvements that Rody felt the GRP could use.
So................ all the TQ internals will work in the GRP.
Spun front bearing? If the crankcase isn't too worn, you could spread a thin film of Loctite sleeve/bearing retainer on the crankcase front bearing bore and a thin film on the bearing outer race. That stuff is incredible when it come to filling small gaps and securing one component inside another.
motomatt is offline   Reply With Quote
Old 08-26-2010, 10:07 PM   #15
Dr. Evil's Avatar
Talking Loctite
I put some on about 2 weeks ago. I need a p/s/con rod. I thought if it didn't work, the money would be wasted. Now, I could at least get the TQ engine and have a spare p/s/con rod.
