Old 08-01-2010, 05:33 PM   #1
Unhappy Help!!!!! with nova 4plusc team 2010
Help i bought a novarossi plus 4 c team 2010 and i can't start it. The glow its ok, the fuel, the engine spin,,,, but nothing explote !!!!
ps sorry about my english i am from argentina
pablo737 is offline   Reply With Quote
Old 08-01-2010, 06:22 PM   #2
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Make sure you have the correct needle settings for breakin as well as the correct idle gap
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 08-01-2010, 06:28 PM   #3
i just take the engine and i put it on my car !!!!!!
Old 08-01-2010, 06:35 PM   #4
RacerScott's Avatar
I have the same engine and mine came very rich from the factory. You may need to lean out the low speed and high speed to get the engine to start and maintain a idle. If you have a lot of fuel coming out of your pipe you know its to rich and flooded with fuel.
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Old 08-01-2010, 06:38 PM   #5
i will try that.... i close,, and i open,, and i try,, but i will try again with your recomendation !!!!
thanks
Old 08-01-2010, 06:40 PM   #6
did you prime it before you apply the glow starter?
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 08-01-2010, 06:48 PM   #7
yeap
Old 08-01-2010, 06:50 PM   #8
turn the piston to bottom dead center and heat it up with a hair dryer, prime it, apply glow starter then try start it again...
Old 08-01-2010, 06:51 PM   #9
i did it,,i swear !!!!
Old 08-01-2010, 06:53 PM   #10
are your needles correct? did you check your idle screw and gap in the carb?
Old 08-02-2010, 02:04 AM   #11
merdith6's Avatar
Default Dude
Are you using the glow plug that came in your engine. the last 3 Novarossi engines I've started for the first time had bad glowplugs. try a 97T odonnell plug if it's a turbo........And like above mentioned lean the bottom end about a half turn......that should get u running.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 08-02-2010, 02:34 AM   #12
When in doubt, change you're plug....
My last Nova plug seemed to work, but I were unable to get it to idle steady, ODO97T did the trick!
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 08-02-2010, 08:57 AM   #13
i will try and inform to you what happen. Thx !!!!
Tags
help novarossi
