Old 07-31-2010, 09:50 PM   #1
Default piston and rod mod
here are some pic of my piston and rod not done all the way. still need to even my piston and polish every thing up. tell me what you think bad or good if bad tell me y just dont say crap.
piston and rod mod-dsc02594.jpg   piston and rod mod-dsc02596.jpg   piston and rod mod-dsc02597.jpg
gatorage is offline   Reply With Quote
Old 07-31-2010, 11:12 PM   #2
jmaxey51's Avatar
have you tried running it? if so did it run? looks way off balance and to weak but i may be wrong....
jmaxey51 is offline   Reply With Quote
Old 07-31-2010, 11:58 PM   #3
iam not done with it yet. but i did not cut the center of the rod like some people do. this is a sirio rod and piston so the rod is super strong and the piston is cnc. no jap crap here.
Old 08-01-2010, 01:14 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
The rod is something not to play with. In your hand it may feel strong but running 40.000 rpm you will be amazed what kind of forces are build up, it can run up to 20~30kg for just such a rod....
If it could be made smaller within a safe use then it would be smaller.....
By the way, the rod does flex to take out the peak force, if the rod is made from a very stif material it would shatter into 1000 pieces within 10 minutes. Been there, done that......
Looking at the surface you have to polish a lot, for sure sharp edges are the places where it will crack first and that will also go for the piston.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-01-2010, 02:11 AM   #5
Trader Rating: 44 (100%+)
I am no guru but your mod looks like it does nothing. It looks like you got a dremel and just starting cutting with no specific goal in mind. I hope it works for you please post your findings...and be honest
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-01-2010, 02:53 AM   #6
+1
Looking at your cuts and where you have them I'd have to say that the most you did to your crank was lighten it and put it out of balance. The rod is another story. I'm also no pro, but I think you may have gone too far in knife edging the rod. At the RPM's these motors pull, that's a bit much for the material we use and what we put our motors through.
I'm not sure why we would want to really modify our motors nowadays? Back in the 90's, we used to cut cranks and sleeves for more flow and power back then. But now, the motors are so overpowered I'm not sure why you might want to risk the motor to get a little more power. Before cranks and sleeves were plain with no turbo cuts or porting cuts which is why we did it back then. I've run modified's from EB mods, RB mods, CEO, Hot Mods, OS Speeds, and JP's and while they are great motors it's hard to justify these costs to newer racers who need more track time in order to use the power.
Good luck with your motor and I hope you will still have a reliable motor when you're done.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 08-01-2010, 05:44 AM   #7
j_blaze14's Avatar
Trader Rating: 34 (100%+)
all modders started somewhere, a few i tried at first were pretty ugly, but ran. some of the guys that have been doing this a while are so good you see the parts and you almost don't want to run them.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 08-01-2010, 07:50 AM   #8
if you think i cut to much look at this pic. this is a onroad rod it is thick and this more has a smaller piston than most .21 i think the rod might belonger to but the crank is longstorkeand being long stork it will have a little less stress on the hole motor.
Old 08-01-2010, 08:20 AM   #9
Trader Rating: 14 (100%+)
You went this far, run it. No reason for all that work and not seeing how it performs, who knows, maybe it's not as bad as it could be. As Roelof said, you need to polish the hell out of that rod. You need to round off all of the pointy surfaces, anything pointy and not rounded off is a stress spot waiting to happen.
DuckStang is offline   Reply With Quote
Old 08-01-2010, 08:40 AM   #10
Roelof's Avatar
One rod isn't the other.... The material is making the specs and if a rod is much thicker then you can imagine it is made from a less stronger material.....
Old 08-01-2010, 12:29 PM   #11
22Racer's Avatar
Trader Rating: 67 (100%+)
I wouldn't take any material off a rod, way too risky. You probably could not tell a difference or even measure a difference in weight. When modding an engine timing is everything.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 08-01-2010, 12:34 PM   #12
Roelof's Avatar
Yep, ony tiny change at the crankshaft timing will do a lot more than all tose fancy cuts.....
Old 08-01-2010, 01:01 PM   #13
This is 100% true all I was saying is that it looks like he was just cutting and didn't have a certain goal eg more overall power,more bottom, more fuel eco or more top. I will say this you have way more gull than me because I would never cut my engine at least not to that extent. The most i've done is mod an old side exhaust opening so it would match the port on the engine(increased flow). I have toyed with the idea of doing small knifing on the sleeve but I haven't found a motor I am comfortable trying it on. Anyway good luck with your mod I hope it works out for ya!
T5M 7.5
22 3.0 7.5
Old 08-01-2010, 01:21 PM   #14
captain america's Avatar
It doesn't really matter what "we" think. The only thing that matters is, when you re-assemble your mill, does it run better or worse than it did before?
The fact that it looks like it was vandalized and mutilated is irrelevant, but humorous from a story-telling perspective
captain america is offline   Reply With Quote
Old 08-01-2010, 01:28 PM   #15
McFly505 is offline   Reply With Quote
